07-20-2013, 11:16 AM   #1
Ricoh Pin removal
I wanted to remove the Ricoh pin from a very nice 28mm lens. Along with the ricoh pin came another pin, and now I can't seem to find where this other pin came from. An interesting note is that even a K1000 doesn't recognize this lens when its attached, (the built in light meter doesn't work).
So, I hear that a local store - will do service work on lens' - after a month and a half - they tell me they wont do anything cause someone else has opened it. Why they just couldn't have told me that to begin with ... sheesh... its a good thing that I have other 28mm lens.
What would you do?
Liz in Calgary
07-20-2013, 11:43 AM   #2
slip's Avatar
QuoteOriginally posted by Liz_in_Calgary Quote
What would you do?
Liz in Calgary
Get a dremel tool with a grinding wheel attachment and carefully grind it off. Worked well for me
Good luck
Randy
07-20-2013, 12:09 PM   #3
jatrax's Avatar
Pictures of the pin, mount etc might help. There are many on this forum who have removed the Ricoh pin and might be able to recognize where the extra pin came from. I assume you still have all the pieces? I would try posting pictures here first and maybe someone can help. If not you could try posting it to Eric and see if he will take a look. He should be able to tell you if it is repairable or not at least. You would be out the postage of course either way.
07-20-2013, 09:06 PM   #4
Pieces
Thanks for the reply. The pieces pic was taken with the lens and a teleconverter - its still useable. and now I've lost that teenytiny ball bearing...
oh well...
PENTAX K-01  Photo
PENTAX K-01  Photo
28mm, k-mount, lens, pentax lens, pin, ricoh, ricoh pin, slr lens
For Sale - Sold: Ricoh XR Rikenon 50 1.4 (non-Ricoh Pin) with Leather case. isb.deep Sold Items 4 05-19-2013 08:54 AM
Ricoh Pin Lens Removal Instructions - From Sears Itself Sagitta Pentax SLR Lens Discussion 1 08-13-2012 06:35 PM
Ricoh Pin ? leftyunderpar Troubleshooting and Beginner Help 5 07-20-2012 12:54 PM
Ricoh Lens Pin Question alamo5000 Pentax SLR Lens Discussion 14 05-30-2012 10:48 AM
For Sale - Sold: Ricoh 55mm f/1.2 (no Ricoh pin!), Voigtlander 40mm f/2 Ultron feilb Sold Items 4 11-22-2011 07:47 PM
All times are GMT -7. The time now is 09:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
