03-20-2008, 10:25 AM   #1
Confused about angle of view
I'm confused about the angle of view of two lenses. The 10-17mm and the 12-24mm.
On the pentax website it says the 10-17mm has a angle of view of 180 - 100 degrees and the 12-24mm has an angle of view of 99 - 61 degrees. If the two lenses overlap from 12mm through 17mm how can their angle of views not overlap at all.
Thank you for any information
JZ
03-20-2008, 10:27 AM   #2
The 10-17mm is fisheye. The 12-24 is rectilinear. Here is a comparison of the 10-17mm and a Sigma 10-20mm (another rectilinear wide-angle which is actually wider than the 12-24)
Pentax 10-17mm Fisheye vs Sigma 10-20mm Photo Gallery by alinla at pbase.com
03-20-2008, 11:12 AM   #3
Kguru's Avatar
The 180 degrees fov of 10mm fisheye counts from corner to corner.
Take a pic with a tall building right on the edge of pic, the top part of building will curve in. If you correct the fisheye effect to make building vertically straight, the corner part beyond the building's top floors stretches out like a thin spike. Crop this spike you crop away a large part of the 180o. All in all 180o fov looks impressive but in fact gives you just a thin spike of extra picture at the corners. Side to side fov is around 110-120o only.
03-20-2008, 07:47 PM   #4
SpecialK's Avatar
Here's the comparison I posted a while back.
10-17mm, 12-24mm, angle, degrees, k-mount, lenses, overlap, pentax lens, slr lens, view
LCD Screen - Best angle to view it at. auspentax Pentax DSLR Discussion 2 07-23-2010 09:13 PM
Confused - What wide angle lense? molko Pentax SLR Lens Discussion 6 03-25-2010 04:56 AM
Right angle view findersfor K-7 nikuyakun Pentax Camera and Field Accessories 2 10-10-2009 06:52 PM
Right angle view finder Moose Pentax Camera and Field Accessories 13 11-21-2008 06:21 PM
250mm Gives Different Angle of View??? Snapshot12 Pentax SLR Lens Discussion 22 09-26-2008 09:03 AM
All times are GMT -7. The time now is 05:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
