07-25-2013, 10:03 AM   #1
help with Lens choice please
Firstly I would like to say hello, I've been lurking on here for a while and only just got round to joining.
Next my question, I think I may benefit from a zoom lens. At present I mainly use a da 35mm, A 50mm, m 28mm and m135mm lens. I sometimes feel I need something a little longer but unfortunately budget is my issue at the moment (hence the Mf lenses)
My budget will allow me a new tamron 70-300mm or a second hand pentax 55-200mm, I just wondered which one you guys would go for?
Thank you
07-25-2013, 10:13 AM   #2
Emperor and Senpai
VoiceOfReason's Avatar
If you mean the 55-300 Pentax (and not the 50-200) it is a well regarded lens, but the Tamron is decent too, and it will come with a warranty. If you trust the seller then I'd go with the Pentax 55-300, if things are iffy then the Tamron would be the way to go.
07-25-2013, 11:17 AM   #3
The DA 55-300 and F (or Takumar) 70-210/4-5.6 are the better budget AF zooms. I slightly prefer the latter. Pentax and Vivitar have great, classic MF zooms as well.
You won't get as good a quality as your primes, however - particularly at over 135mm. Something like the K200/2.5 will give you excellent photos, but it costs maybe twice as much as the DA 55-300.
07-25-2013, 09:27 PM   #4
carrrlangas's Avatar
QuoteOriginally posted by DSims Quote
i think the DA50-200 is better than the F70-210. Smaller, lighter, modern coatings, WR option. Only thing F70-210 has is that you may get it for really cheap if you look for it / are lucky enough.
See this comparison done by @Just1moreDave:
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/220956-super-m...omparison.html
The DA55-300 is a bit larger and heavier and bigger than DA50-200. But it has more contrast wide open and is faster through the range.
07-26-2013, 02:30 PM   #5
QuoteOriginally posted by carrrlangas Quote
The F70-210 is weak between about 180mm to 210mm. Most of these test shots were taken at 210mm, so this is not a good comparison. I'm surprised Dave did these tests at the long end - perhaps he hadn't noticed this characteristic of the lens.
I've never even owned the DA50-200, because the images I've seen from it are lackluster. With the F70-210 I get nice images, similar to those I've seen from others. But as with any lens, you must use it with settings where it performs well. And the F70-210 performs well throughout most of its zoom and aperture range.
budget, k-mount, lens, lens choice, pentax lens, slr lens
Help with lens choice theWags Troubleshooting and Beginner Help 4 11-03-2012 07:53 PM
K-30_Ready to Buy_need Lens choice help please Mr_Yo Pentax SLR Lens Discussion 6 09-17-2012 08:05 PM
Please help me make a choice. misbehave Pentax DSLR Discussion 24 07-09-2012 05:59 AM
Please help me with this lens choice.. Tomm Pentax SLR Lens Discussion 11 06-23-2012 07:43 AM
Help with new camera choice please Arpe General Talk 14 06-17-2009 06:15 PM
All times are GMT -7. The time now is 10:55 PM. | See also: NikonForums.com, part of our network of photo forums!
