And while you are at it, I recommend a ring flash / light. I went w/ an inexpensive one, and it works fine, but you probably want one that can function simply as an LED ring light. (Ie, not necessarily flash. The light makes for much more reliable metering. I also like one that allows you to illumine just one side or the other of the light so that can get some shadows to show depth if you want.)
HERE is a review of the one I got.
