07-27-2013, 12:43 PM   #1
6BQ5's Avatar
Easiest M42 auto only mod?
My dear wife bought me a "vintage" Yashica TL Electro X kit from an estate as a birthday present. The kit contains three M42 lenses but all of them are auto-only. I would like to convert them to manual mode. According to my forum searches I found that the two most popular conversion methods are:
1) Take apart the back of the lens and put a spacer inside that pushes the pin as if the aperture function is always actuated.
2) Glue the pin down.
I don't want to take anything apart because I'm afraid that I won't be able to put it back together correctly. Plus, some of the lenses don't have any screws holding the back. I would need to take apart a bathtub plug to unscrew big pieces apart.
I feel hesitant about gluing the pin down because I'm afraid that the glue will eventually fail and bits of it will chip off inside the lens/camera.
Are there any alternatives to disassembly and gluing?
07-27-2013, 12:51 PM   #2
Just1MoreDave's Avatar
Wedge the pin, maybe something like a toothpick?
07-27-2013, 12:51 PM   #3
Jean Poitiers's Avatar
I would super-glue ... I have done it several times without any problems ... J
07-27-2013, 01:44 PM   #4
I glued my Yashica 50mm f1.9 and Fujica 55mm f1.8, no problems at all. There isn't a lot of force on the pin, so I doubt the glue will ever fail. Just used standard super glue and used a needle to hold the pin down until the glue had dried enough to hold it.
07-27-2013, 02:22 PM   #5
Lowell Goudge's Avatar
A short section of a ball point pen refil does the trick
glue, k-mount, kit, lenses, m42, pentax lens, pin, slr lens
Can anyone recommend a good glue for an m42 pin on an auto only lens? srn121 Pentax SLR Lens Discussion 9 04-04-2012 06:27 PM
Camera mount for Pentax M42 Auto Bellows? (NOT about M42-K adapter) baj Pentax Camera and Field Accessories 9 10-24-2011 10:42 PM
How to fix a auto-only M42 lens so it becomes a manual one sterretje Pentax SLR Lens Discussion 5 05-16-2010 10:12 PM
M42 Auto Only Lens Modification hinman Pentax SLR Lens Discussion 23 03-06-2009 02:07 PM
All times are GMT -7. The time now is 09:03 AM. | See also: NikonForums.com, part of our network of photo forums!
