08-01-2013, 01:08 PM   #1
6BQ5's Avatar
Anyone here tried Purosol?
I am looking for a lens cleaning kit and I found this one made by Purosol.
Amazon.com: Purosol Lens Cleaner Large Clamshell Kit: PUROSOL: Camera & Photo
Has anyone here tried this? Is it any good? Alternatives?
08-01-2013, 01:14 PM   #2
Na Horuk's Avatar
For lens cleaning? Not sure you'd need that. With Pentax' SMC you can usually just use a rocket blower or a gentle cloth to get rid of dust and finger print oil.
Just remember all those second hand lenses for sale on websites that have notes like "cleaning marks on front element". Don't want to overdo it. A little dust doesn't even show up
08-01-2013, 01:18 PM   #3
JinDesu's Avatar
For cleaning what, exactly?
As far as fingerprints go - Lenspens are pretty much perfect for that.
08-01-2013, 02:12 PM   #4
6BQ5's Avatar
I was thinking of an all-lens cleaner: Pentax SMC, vintage "coated" from the 60's and 70's...
Short term, I need to clean off an oily fingerprint on the rear element of two lenses, one being a SMC-A 50mm f/1.4 and the other a 35mm f/2.8 Lentar.
08-01-2013, 02:43 PM   #5
JinDesu's Avatar
If it's fingerprints, I really would recommend using lenspen. Safe, effective, and leaves no residue.
If you want an all-purpose cleaner for when you get the odd sticky substance on the lens element, then probably purosol is good. Although I use the little methanol solution that comes with sensor swab.
08-01-2013, 05:35 PM   #6
I most often use a Lenspen myself, but for fingerprints, Residual Oil Remover (ROR) works well:
Screen Cleaner | Lens Cleaner | LCD Screen Cleaner
You can get it at B&H etc.
k-mount, kit, lens, pentax lens, purosol, slr lens
Anyone tried the DNG Flat Field Plug-in Docrwm Digital Processing, Software, and Printing 4 05-13-2013 04:39 PM
Anyone tried drawing distance scales on DA 35mm? Na Horuk Pentax SLR Lens Discussion 8 01-13-2013 08:29 PM
Anyone tried Yongnuo YN-04II Flash triggers? jeztastic Flashes, Lighting, and Studio 19 02-04-2012 07:55 PM
Has anyone tried the Polaroid Tri-Mode fiash triggers? sjwaldron Flashes, Lighting, and Studio 12 12-14-2011 01:14 PM
Anyone tried Zeiss 28mm or 35mm? eleventhirteen83 Pentax DSLR Discussion 31 11-06-2011 08:23 PM
All times are GMT -7. The time now is 10:51 AM. | See also: NikonForums.com, part of our network of photo forums!
