Hi,
I recently found a Vivitar Series 1 28mm f/1.9 (M42) with the aperture stuck wide open. After taking it apart until I reached a set of screws that I couldn't get loose and reassembling it, the aperture now works unless the lens is focused at infinity. When the focus ring reaches the infinity-mark, it tightens up and keeps the aperture from beeing closed. This happens about 3mm before the focus ring reaches infinity, at that point the aperture can still be opened up but when it is stopped down nothing happens. As soon as the lens is focused a little closer, the aperture snaps where it belongs.
Secondly, the focus scale seems to be off, when I focus at a building that's ~100m away with the split-prism of my Minolta XD-7 or my Pentax Super A (both with adapters with the correct flange distance), the focus scale on the lens shows ~1,2m.
The point where the aperture gets stuck is at about 10m on the focus scale, so I could adjust it if it wasn't for this:
(shown is the K-mount version, mine doesn't have the second set of F-stop number on the aperture ring)
The position of the focus mark can be adjusted but the position of the aperture mark is changed at the same time so I'm looking for a way to independently adjust the focus scale.
Maybe someone here can help me.
Edit: I have now move the focus/aperture mark by one stop so the set f-stop now shows on the left instead in the middle. It works as long as I remember the change but it's not exactly ideal.
(It now has half-stops from f/16 to f/2.8 and is effectively stepless from f/2.8 to f/1.9)
regards
Jan
