08-10-2013, 06:04 AM   #1
slip's Avatar
F4 and indoor sports
How big of a difference would going from a 2.8 to f4 make with indoor sports?
Typical lighting conditions would be f2.8 1/125-1/250 with ISO 3200 on the k5iis
Thanks
Randy
08-10-2013, 06:50 AM   #2
manacho2005's Avatar
If that's what you're shooting at and want the same exposure, you would bump your ISO to 6400. You could lower your shutter instead, but unless it's chess your shooting, you'll get motion blur.
08-10-2013, 06:54 AM   #3
Docrwm's Avatar
Double the ISO at f4. Awfully slow shutter for sport photography though. This is why I have a 70-200/2.8, a 50/1.4, and a 35/2.4.
08-10-2013, 07:52 AM   #4
VisualDarkness's Avatar
Well, it all depends. I use a F2.8 for most of my sports stuff but many of my shots are are at F3.5-4 mostly due to wanting more depth of field. I don't know how the AF will react though with an even slower lens in bad lighting. Though I've used my DA* 300/4 a couple of times with nice results.
08-10-2013, 09:04 AM   #5
slip's Avatar
Thanks everyone
I think I will keep my Sigma 70 - 200 f2.8
Cheers
Randy
08-10-2013, 01:37 PM   #6
mee
QuoteOriginally posted by slip Quote
Thanks everyone
If you get super curious you could also experiment/approximate by using your sigma lens, setting the camera to a fixed f/4 and seeing how well it goes..
and shoot in RAW mode
08-10-2013, 01:44 PM   #7
QuoteOriginally posted by mee Quote
Though, that won't affect the AF as a F4 lens would. THough as I said before, I've used my 300/4 for indoor sports.
08-10-2013, 05:09 PM   #8
rbefly's Avatar
Extender?
Hi Randy,
Another option might be to try a good-quality 1.4- 1.5 tele extender. This should put the Sigma at 300mm (roughly) and f/4.0. If you're only going to use the longer range occasionally, it might be the most cost-effective way to increase the range, and would be a lot more portable!
Ron
f4, k-mount, pentax lens, slr lens, sports
Indoor sports & the Q? GibbyTheMole Pentax Q 9 02-10-2013 10:11 AM
inexpensive, fast telephoto prime or zoom for indoor sports photography monkadelicd Pentax SLR Lens Discussion 17 10-05-2012 09:39 AM
How is 50-135 for indoor HS sports? cubsfan61 Pentax SLR Lens Discussion 15 01-27-2012 09:34 AM
Which 50mm version for indoor sports? 35mmGun Pentax SLR Lens Discussion 16 11-18-2011 04:13 AM
Indoor sports photography at gymnastics mradice Pentax SLR Lens Discussion 7 11-28-2006 04:55 PM
All times are GMT -7. The time now is 03:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
