08-12-2013, 02:19 PM   #16
QuoteOriginally posted by Just1MoreDave Quote
I am not sure they could ever decripple the mount and make it work as well as people expect.
The main advantage of decrippling the mount would be that non-A contact K-mount lenses could be used in Av mode in the manner they were designed for. Unfortunately, given that Pentax no longer sells non-A contact glass, there is no incentive for them to do so. After all, cameras sell lenses, and if what the user buys is not made by Pentax...
08-12-2013, 08:06 PM   #17
6BQ5's Avatar
Even simpler than that. It is a simple on/off based ....
Nice! Thanks!
08-13-2013, 05:38 PM   #18
JimJohnson's Avatar
Even simpler than that. It is a simple on/off based on the position/pattern of the contacts. The logic is essentially the same as a bit array in computer programming. See the table 2/3 down at the linked page below:
Features and Operation of the Ka Mount
Thanks Steve, I was going to add a different link to the same table.
https://www.pentaxforums.com/forums/pentax-flashes-lighting-technique/190819-...ml#post2021062
The above link is to some research I did regarding using P-TTL controlled flash with pre-A series lenses. Basically it uses a technique where you make the camera think an M series or K series lens is an A lens. However, I also used the same technique to use manual f/stops on an A series lens. In theory, it should have made no difference if the lens is in the A position or manually setting the same f/stop on the lens (body told which f/stop used); in practice the histograms say otherwise. The pdf in the above link makes for interesting viewing.
aperture, camera, change, k-mount, lens, pentax lens, slr lens
Will my old lenses work with a K-5 body? James Moritz Visitors' Center 6 08-01-2012 07:50 PM
How do AUTO Takumar lenses work on a DSLR? Pepe Guitarra Troubleshooting and Beginner Help 2 02-10-2012 02:18 PM
How well do M42 lenses work on K mount pentax cameras? geekette Pentax SLR Lens Discussion 6 04-13-2011 03:20 AM
Old Super A lenses do no work on my k-r yancheelo Pentax K-r 12 04-12-2011 12:14 PM
How does burst on K20D work mechanically? barondla Pentax DSLR Discussion 6 05-11-2008 05:14 PM
All times are GMT -7. The time now is 01:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
