Veteran Member Join Date: Oct 2006 Location: Chicago suburb, IL, USA |
Hi gsrokmix,
I'll add my 2¢ here if you don't mind.
I'm primarily a birder with about 8 yrs of experience with Pentax DSLRs with that use in mind.
Let's go through the options you listed, and one other mentioned.
FA*300 f4.5 -- Excellent performing lens. Screw Drive AF only. Still works well with the F 1.7x AFA though the effective max aperture with the AFA is f7.7 -- AF will work reliably down to pretty dim overcast -- a bit darker than when you stop seeing shadows. This is the lightest weight alternative mentioned. The f4.5 max aperture allows use of a 67mm front element, and AF/MF switching on the lens is accomplished by pulling/pushing the focus ring back/forward with the ring in any position. I've had this lens for about 7 years, and it's my most used lens -- usually with the AFA -- There is no OEM tripod ring/foot for this lens, but I've found a couple of tripod rings that work with it -- I shoot it 97% handheld, even with the AFA. The screw drive AF allows this lens to AF with any KAF 1.4x TC that can mount to the lens (apparently the Sigma EX 1.4x APO DG TC will not mount, but the Sigma EX 1.4x APO will -- I can personally attest to this latter -- I have one).
DA* 300 f4. -- Slightly sharper than the FA* -- 1/3 stop faster (not much really) but that means it needs a 77mm front element, so it's a bit heavier. SDM AF only (though it has a screw drive mechanism -- Pentax doesn't allow the user to use it unless the body is not SDM compatible). Since SDM compatible SDM bodies ID the lens as SDM, screw drive AF TCs will not AF with the DA*, and PZ TCs (that have the same contact riser) will power the AF motor in the lens, but AF is very slow and unreliable from my experience. There is a 1.4x SDM projected from Pentax, but it's been literally several years since they first suggested that one is in the works, and we haven't seen anything yet, so I'm not holding my breath. The 1.7x AFA will work well with this lens. This lens also includes a tripod mount and is currently pretty easily available either new or used. The dA* also has a very close Minimum Focusing Distance of @ 4 feet. The rest of these lenses focus to about 6 ft -- the Tamron 60B is @ 8 ft.
Sigma EX 100-300 f4 -- an excellent lens. Easily in the same IQ class as the prime alternatives and better IQ than all other 300mm alternatives but the F*, FA*, and DA* Pentaxes IMO. The differences between these first three are really pixel peeping differences -- I doubt that anyone could actually distinguish between them from prints. This lens does have the versatility of it's zoom range, but you pay a weight and size penalty of about 1 lb, so this is a 3+ lb lens compared to the Pentax primes which are both close to 2 lbs. This would not make much difference if you prefer to shoot from stationary positions, but I usually shoot opportunistically, so I wander around a lot, and carrying an extra pound on the end of my camera and swinging it up and around makes a big difference for me during the course of a day in the field. This lens comes with a removable tripod collar.
Tamron SP 300 f2.8 mdl 60B Adaptall 2. This is a great lens. The f2.8 max aperture allows for stacked TCs if even more reach is desired. With the AFA and a good 1.4x TC, you can get a very serviceable 714mm f6.7 AF lens. With the AFA alone, it's a very good 510mm f4.8. The lens is sharp at f2.8, but gains a bit from stopping down. Yes, it does not control CA and PF as well as more modern lenses, but if given the choice between getting a shot and dealing with some color aberration in PP and not getting a usable shoT, I'll deal with the CA/PF. If you want a 300mm f2.8 lens for Pentax that controls CA/PF better, then you have two choices -- A sigma EX 300/2.8 APO, or the FA* 300/2.8, at least $2K or at least $3K respectively used. They both are also a touch sharper, but my Sigma is not as contrasty wide open (it's a pre DG version), and the FA* is pretty much of a beast -- yes, I own and use all three.
My goto kit is a K-5 or K-5IIs with the FA* 300 f4.5 + 1.7x AFA. I use the AFA a lot, so the MF prefocus is second nature to me, and AF with this combo is very quick and efficient, and refocus is extremely efficient since the AFA works as a focus limiter. When the DA* 300/4 came out, I tried one and was impressed, but decided to stick with my FA* because the differences weren't enough to pop another $1K+ in my mind. Some say that the screw drive motor sound scares away birds, but I have not found this to be the case, and I usually shoot close -- within 15 ft if I can.
BTW, I've never wanted a 400mm f5.6 since I always seem to want more reach, and f5.6 is really too slow to get AF with any TC since the limit for AF is somewhere around f8. With an f5.6 max aperture lens, a 1.4x TC will give you an effective max aperture of f8, and anything above 1.4x will put you into the no AF very dim VF range. It should be noted that the K-5 and K-5IIs will AF with lenses with effective apertures slower than f8, but it's touchy, needs a lot of light/contrast, and is pretty unreliable in general. For practical use, I don't go there.
Scott
