03-23-2008, 05:43 AM   #1
simons-photography's Avatar
how much should i worry about dust
need I be paranoid about NO dust at all or droplets of water on the lens when out shooting. I was out in the snow this morning and it drizilled so I couldn't help the lens having so water droplets on it, of course normally its impossible to keep dust off a lens when you are out shooting. need I worry too much about keeping it spotless and just give it a wipe when its getting like 10+ specs ?
03-23-2008, 06:44 AM   #2
TaoMaas's Avatar
I generally check my lenses for dust right before I plan to use them. Most of it can be removed with a puff of air. I use a soft brush on more stubborn particles. (My wife uses a brand of make-up that comes with a free brush. She's given me a couple of the new, clean brushes and I've found that they fit perfectly inside an empty film container.) If there's a speck or two left on the lens, I usually don't worry about it, especially if I'm using a lens hood with that lens. A lens hood is helpful because those dust spots are more prone to showing up if light hits them. If they're shaded, they're less likely to degrade the image. Droplets of water are another matter. They almost always show up in a shot, so I do my best to dry them off as soon as possible or avoid getting them altogether, if I can.
03-23-2008, 06:46 AM   #3
Buddha Jones's Avatar
I would do my best to keep it from getting rained on, unless you have one of the weather sealed ones, water is very capable of getting into the smallest cracks and crevaces.
03-23-2008, 06:57 AM   #4
I have a K10D so the body is splash proof, I wanted to take pictures I had to put up with a little water. There were a few water droplets on the lens if I tried to wipe them off what would I do ? point it up wipe it and get more splashes on it while I'm trying to wipe it. I always use a lens hood
03-23-2008, 07:36 AM   #5
TaoMaas's Avatar
I once attended a seminar with a couple of cameramen from CBS. They were showing what they carried in their "bag of tricks". One thing they suggested was carrying a small piece of chamois to use in wiping drops of water off the front of the lens. It seemed like a decent idea although I've never tried it.
03-23-2008, 07:42 AM   #6
hm problem is if your already out in the wet you are going to take off the hood wipe it and by the time you get the hood back on its wet again
03-23-2008, 07:46 AM   #7
Moderator Emeritus
I don't worry to much about a few drops on the barrel and try to find a place to dry or clean the lens as soon as possible. I've had snow and rain on the barrel a few times without any issues. If I have the forethought, I carry a couple of plastic bags and elastic bands in the camera bag that are tube shaped (our local flyers (advertisments) are delivered in the perfectly shaped plastic bag). These are great for covering the lens barrel from end to end in more damp conditions.
As for water drops on the front end, well that is the time a UV filter can come in handy ( I don't use them most of the time unless near the ocean etc). A hood is the most important add on for each lens. Carry a lens cleaning tissue kit in a ziplock bag and find a dry spot to clean the front. Don't all you guys have 42 umbrellas each? Bring one with you for a cleaning "shelter".
03-23-2008, 11:13 AM   #8
TaoMaas's Avatar
QuoteOriginally posted by Peter Zack Quote
I try to keep a semi-heavy plastic bag stashed in all my camera bags. If I fold the bag up carefully, I can usually fit it into one of those flat pockets that most camera bags have either on the back of the case or in the top. I can't tell you how many times that has saved me.
03-23-2008, 02:02 PM   #9
erm nope then the filter will get the water droplets, I'm not really refering to equipment safety but dust and water droplets interfering with image capture
03-23-2008, 02:09 PM   #10
After taking my K10D around the world in less than 9 months, being in very dusty plances and having been making photographs in the rain: there is a little spec of dust I can see in my viewfinder, no dust or other problems with lenses or on the sensor.
I'm a bit sloppy, I carry my equipment around in a small, soft, shoulder bag, together with other stuf like an umbrella etc. However, my dust reduction is always on and I try to use my DA*16-50mm exclusively when shooting in rain.
- Bert
droplets, dust, k-mount, lens, pentax lens, shooting, slr lens, water
Pentax K-7 Dust Alert and Dust Removal Functions brosen Pentax DSLR Discussion 9 02-09-2016 04:43 AM
Blowing dust. Will I get more dust inside ? alphalt Pentax DSLR Discussion 7 05-12-2010 10:09 PM
no need to worry about Pentax at Ritz Camera kenyee General Talk 12 03-07-2009 09:41 AM
Newbie here w/ some huge pics (thumbnails in thread, don't worry) Volvo244T Post Your Photos! 4 09-09-2008 01:34 PM
I worry about abandoning DPR (here is why) russellwolff General Talk 9 11-25-2006 07:58 PM
All times are GMT -7. The time now is 12:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
