08-16-2013, 12:26 AM   #1
old4570's Avatar
FD to PK adapter
Anyone have experience with the Canon FD to PK adapters ?
Any quality loss , etc ... If you remove the lens from the adapter , it becomes a small macro tube ? ( I assume )
Thank you
08-16-2013, 02:02 AM   #2
I believe it works out to be about 13mm of extension tube with the registration distance difference and the thickness of the adapter. Anything wide angle is going to be strictly close up use only, but you'll be able to get some distance with longer lenses.
08-16-2013, 02:57 AM   #3
Douglas_of_Sweden's Avatar
You will find that we have tested it quite a lot with and without glass in the adapter-"club": https://www.pentaxforums.com/forums/pentax-camera-field-accessories/96884-ada...addiction.html
With glass it is like a converter. Not a good one, but not as bad as you would expect from a converter that looks like it is only made of two cemented glass elements.
Without glass it is mostly useful for longer focal lengths and macro. A short focal length give you a very small working distance. I've used it a lot on the Canon FD 200 mm f4 macro 1:1 lens, where I can focus to about 2.5m, which is enough since one would anyway mostly buy that lens to use it as a macro.
adapter, fd, k-mount, pentax lens, pk, slr lens
PK to EOS Adapter timmijo Non-Pentax Cameras: Canon, Nikon, etc. 11 02-24-2014 01:22 AM
Where to get the genuine m42 to pk adapter from? pasipasi Pentax Film SLR Discussion 34 04-16-2013 11:52 AM
Is FD lens on K-01 (without glass adapter) and focus to infinite possible? dmb video Pentax K-01 19 01-25-2013 01:35 PM
Canon FD to PK Adapters... any good? Sagitta Pentax SLR Lens Discussion 10 11-07-2012 07:21 PM
canon fd - pk adapter question? ripit Pentax SLR Lens Discussion 9 10-31-2011 02:10 AM
All times are GMT -7. The time now is 09:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
