08-21-2013, 09:35 AM   #1
npridgeon's Avatar
Manual lens yellow button
On a lot of manual lenses there is a yellow round button on the aperture ring, no...above the aperture ring. It doesn't seem to do anything when pressed. What exactly is it's purpose, and if it's missing, what affect will it have on the lens? I saw a lens on ebay claiming to be mint, yet the thing was missing.
08-21-2013, 09:45 AM   #2
Docrwm's Avatar
Its not a button but a marker to help you know how to orient the lens by touch to mount it on the camera.
08-21-2013, 10:49 AM   #3
I have a Pentax M lens where this yellow button came off. The lens works perfectly without it.
08-21-2013, 11:18 AM   #4
It's funny - that little button looks a lot like a white balance cap (you couldn't use it as such, but oddly similar design). But it's just a tactile point on the lens, nothing more.
08-21-2013, 11:45 AM   #5
monochrome's Avatar
In the KX Manual, Pg. 6, it is called the "white plastic bump." Over time many of them have yellowed In some cases the bump was more yellowish or has fallen off. [CORRECTED per comments below]
3.
"In the dark, when the red dots are difficult to see, align the white plastic bump on the lens barrel with the lens release lever by touch, then turn and lock in as above."
08-21-2013, 11:48 AM   #6
Docrwm's Avatar
In the KX Manual, Pg. 6, it is called the "white plastic bump." Over time many of them have yellowed or fallen off.
3.
Some of the old ones are UV reactive so if you want to save your night vision you can use a UV flashlight and be able to pick up the dot (many of the red lines on older lenses were also UV reactive).
08-21-2013, 11:51 AM   #7
monochrome's Avatar
QuoteOriginally posted by Docrwm Quote
So if I put an old lens with a yellowed white plastic bump in a south facing window for a week, will that clear the yellowing?
08-21-2013, 12:32 PM   #8
Might be worth pointing out that the location of the lens release button has shifted upward slightly on some newer bodies, so the little lump doesn't quite line up with the lens release any more. On film bodies, the alignment is perfect.
08-21-2013, 12:40 PM   #9
Docrwm's Avatar
QuoteOriginally posted by Tanzer Quote
It does get you very close though and in the dark that is a big plus.
08-21-2013, 01:37 PM   #10
3.
If it's too dark to see your CAMERA, how are you going to take pictures? Was there an SMC-A 50/0.05 that I missed? (Imagine that... the front element would be something on the order of a meter across!)
08-21-2013, 03:06 PM   #11
Cheers. I just wanted to make it clear, if the OP has a newer camera model and was wondering why it didn't line up exactly.
QuoteOriginally posted by thornburg Quote
When shooting film, it is common practice to mount/unmount lenses in a dark environment to keep out excess light.
Probably a bigger reason to change lenses in a bag, by feel, is to keep out dust, such as when you want to change lenses at the beach. This would apply to any interchangeable-lens camera,
08-21-2013, 03:27 PM   #12
Eek!
You keep my lenses away from the sand, whether they're mounted to a camera or not.
08-21-2013, 03:32 PM   #13
@monochrome
Back in the beginning of the eighties, I bought several M and A lenses (used, but none of them very old). Some of them had a white bump, some a yellow one.
So I always thought their original color can be white or yellow, and it just marks different lens lines. But I never tried to investigate. Both of them made changing lenses in the dark much easier.
08-21-2013, 04:02 PM   #14
8540tomg's Avatar
As above I have seeral M and A series lenses. The colour of the alignment pip hasn't changed over time in my experience. Not really an issue in any case. It will serve it's alignment function no matter what the colour.
Tom G
08-21-2013, 07:06 PM   #15
It's not a common practice at all- and is completely pointless. In an SLR, the shutter keeps light from reaching the film when you change lenses. If the shutter is damaged you will have a light leak whenever you take the lens cap off, whether you change lenses or not.
aperture, button, k-mount, lens, pentax lens, slr lens
AEL with shutter button using manual lenses? kanzlr Pentax K-5 9 11-17-2013 08:35 AM
Manual Lenses, Green Button and Flash Neil MacG Pentax K-01 2 12-21-2012 01:03 AM
Green Button Metering with Manual Lens zombieCat Pentax DSLR Discussion 4 02-15-2010 06:07 AM
K100 Super Manual Lens Yellow Tint/Overexposed??? Grzldvt Pentax SLR Lens Discussion 8 06-09-2009 05:13 PM
K10D and Green Button Manual Lens Shutter Speed David Pentax DSLR Discussion 4 10-15-2007 12:41 AM
All times are GMT -7. The time now is 04:27 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
