Originally posted by larshalvar Thank you for sharing great photos with us guys! And for good advice all of you. For now I have decided to start off with a relatively cheap Sigma 400mm (almost sure it is non-APO), and be looking around for a decent and cheap second hand version of the DA 55-300. (I do actually have the FA 100-300, (silver), but I have not felt particulary comfortable with it yet. Maybe will try to use that one a bit more as well.
Does any of you have any experience with non-APO versions of Sigma tele-lenses? does the PF and CA make this a hopelessly difficult lens to use? The lens I'm buying is the multicoated Sigma 400mm F5.6 Telephoto lens with A-setting on aperture ring.
regards
Any non APO lens will give you similar challenges. Specifically you will see fringing if you do not nail focus. It is that simple. As for "ease of use" that is a judgement call. For a MF lens, there are two conflicting ease of use "wants" fast focusing and accurate focusing. Both are a function of the focus throw, fast focusing is achieved by a short focus throw, typically less than 189 degrees, while accurate focusing is achieved with long focus throw, typically more than 300 degrees.
As you can see, getting both is hard.
My K300/4 is 27 degrees, my vivitar 400/5.5 is 330'degrees. My sigma 70-200/2.8 is only 90 degrees. I have never tried my sigma in manual focus, because with a 90 degree throw accurate focus would be impossible. I like 180-270 for manual focus, if you leave the lens at a middle focus distance when not shooting, moving either way is not too bad. 330 degrees is almost impossible to focus quickly, but is the most accurate. You can only really do this by trial, see what you like and move forward from there
Also note that your selection of a lens with an A setting is a good idea. Start looking at using flash. Works great for birds
