08-28-2013, 09:07 AM   #1
Is it possible to take apart Takumar 28/2.0?
I got this lens with a little bit of fungus inside, right behind the front element (as you can see on picture), but I don't see any screws or ledges which can be used to disassemble it. Any ideas?
08-28-2013, 09:25 AM   #2
boriscleto's Avatar
The screws are underneath the ring with the name on it. You need a rubber ring to remove it.
Something like this
Micro-Tools Europe Tools | Lens Ring Tool Set | buy online
or this
Micro-Tools Europe Tools | Lens Ring Tool 56mm & 67mm#13 Gum Rubber | buy online
08-28-2013, 09:48 AM   #3
QuoteOriginally posted by boriscleto Quote
Something like this
or this
Thanks, I'll give it try! Can't find this rubber tools in my country, looks like I would have to order them online
08-28-2013, 09:50 AM   #4
boriscleto's Avatar
There are other things you can use. As long as it has enough friction to grip the ring and won't damage the front element. Rubber washers, rubber bands...
08-28-2013, 11:09 AM   #5
johnyates's Avatar
Use a rear lens cap and a piece of rubber cut from an old rubber glove.
08-28-2013, 11:53 AM   #6
macTak's Avatar
I use a (rubber) replacement cane tip.
08-28-2013, 12:31 PM   #7
Lowell Goudge's Avatar
QuoteOriginally posted by kitestring Quote
As a simple point of discussion NO it is not possible to take apart a tak 28/2.0. Why? Because it does not exist. You have a tak 28/3.5'
08-28-2013, 12:33 PM   #8
I noticed that, but I couldn't edit post title after it was submitted
08-28-2013, 02:01 PM   #9
TaoMaas's Avatar
Taking it apart isn't the hard part...putting it back together is. This is the voice of experience speaking.
08-28-2013, 02:02 PM   #10
QuoteOriginally posted by TaoMaas Quote
ha, I can imagine is it so hard that better leave fungus as it is and shoot it while there are no visible artifacts?
08-28-2013, 02:18 PM   #11
hoanpham's Avatar
It will take you ten fold of time to get the lens back, often not as good shape, due to infinity adjustment, grease..
Better leave it to pro service. In most cases, the fungus wont affect image quality, just annoying.
Still want to open up? Get a set of real rubber tool to do the job. Then a set of quality JIT screw drivers. Dont lose any part.
Best wishes.
08-28-2013, 02:42 PM   #12
boriscleto's Avatar
QuoteOriginally posted by hoanpham Quote
Best wishes.
The Takumars I have taken apart have flat screw heads. Later lenses have JIT screws, but this may be a US thing...
k-mount, pentax lens, slr lens
Is it possible to use manual flash in TAv mode? ismaelg Pentax DSLR Discussion 3 07-09-2013 11:52 AM
Is it possible to remove the AA filter from a DSLR? TropicalMonkey Pentax DSLR Discussion 7 04-30-2013 12:32 PM
Is it possible to have a perfect RAW photo? PPPPPP42 Pentax DSLR Discussion 48 05-04-2012 10:58 PM
Is it possible to do a manual stroboscopic mode? srn121 Flashes, Lighting, and Studio 3 03-13-2012 05:21 PM
Is it possible to use off-camera flash extension cord with AF360 to make it swivel? raider Flashes, Lighting, and Studio 8 10-28-2007 05:38 AM
All times are GMT -7. The time now is 07:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
