Originally posted by photolady I was saying that since your lens is only 49mm you could buy a step up ring 49 to 52, then just use the clip that comes with the DCR-250 and clip it to the step up ring.. That's what I did because I have two lenses that are 49mm. Or you could do it the way you said. I needed the ring because I have closeup lenses and I wanted to use them on a new lens and the closeups are 55mm So I bought a 49 to 55mm step up ring. That way I can use either the DCR 250 or my closeup lenses..
Thanks so much for clearing that up for me
I also want to look into getting even closer macros. The Pentax 100 does not have an aperture ring, so would it be worth stacking it with a fast prime like 50/1.8 or is there a better way to get more magnification while still keeping up the IQ. I want to get really close shots of water drops and snowflakes in the winter.
