03-25-2008, 04:54 AM   #1
Buffy's Avatar
Vignetting with FA 31 Limited
Some of my recent shots with the FA 31 showed some small vignetting, and I am assuming it's because I had too many filters on it--the UV I forgot to remove, a polarizer, and a red 25. Has anyone else ever had this problem, and am I right in assuming two filters is the limit?
Buffy
03-25-2008, 05:15 AM   #2
I've not noted the characteristic myself. I recommend taking off the filters and try a shot wide open against a white wall, then you'll know if your copy is sound.
03-25-2008, 07:56 AM   #3
aegisphan's Avatar
Stacking filter is not recommended since it introduces light fall-off, degrade IQ, and the setup is prone to flare. Most of the time, two would be the limit (same with Cokin P set up).
03-25-2008, 09:29 AM   #4
Unless you've got a really wide step-up ring. But polarisers get expensive then.
03-25-2008, 09:51 AM   #5
TaoMaas's Avatar
Yep...sounds like too many filters. I think you already solved your own problem, though. Remove the UV if you're going to be using two filters.
fa, filters, k-mount, pentax lens, slr lens
Vignetting as a desired effect? NecroticSoldier Troubleshooting and Beginner Help 7 04-17-2010 10:14 AM
vignetting problem enrod666 Pentax DSLR Discussion 13 12-24-2008 10:04 PM
lens vignetting profiles jani Pentax SLR Lens Discussion 7 12-17-2008 09:43 PM
Distortion-Vignetting-Zooms regken Pentax SLR Lens Discussion 4 07-31-2007 07:06 AM
Oh, the vignetting! mediaslinky Post Your Photos! 6 05-19-2007 06:15 AM
All times are GMT -7. The time now is 01:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
