01-16-2007, 03:12 PM   #1
Teleconverters
Not sure whether this question fits in here but are there any decent teleconverters (1.4) out there with an AF fit?
01-16-2007, 03:35 PM   #2
Paul_C's Avatar
I have this kenko (1.5) which works fine.
01-16-2007, 04:40 PM   #3
roy
roy's Avatar
QuoteOriginally posted by Paul_C Quote
what's the lowest f-stop it will AF??
01-16-2007, 04:49 PM   #4
Paul_C's Avatar
I don't know. I use it on my F* 300 f/4.5 without problems. The AF is a bit louder with it, but I haven't noticed much degradation (if any) in AF performance. I suppose it would depend on the light though.
01-16-2007, 06:07 PM   #5
roy
roy's Avatar
i was wondering because i have a tamron 2x($10) tthat does not with the kit lens, my only AF lens.. works fine with A lenses tho. i'm looking for a 1.4-5x. i was surprised with the 2x tamron as it seems to work well with my primes. i haven't liked the 2x before and only got this one from an auction no one out bid me on at the hi price of 5usd. i may give the kenko a shot
01-16-2007, 06:12 PM   #6
Paul_C's Avatar
Tamron also has a 1.4x that people swear by. It's a little cheaper than the kenko. For me it was a toss-up between the two so I went with what was in stock at the time.
01-16-2007, 06:25 PM   #7
QuoteOriginally posted by roy Quote
If you have the autofocus version of the Tammy 2x try using it in bright light. The instruction sheet that comes with it says it should only be used on lenses faster than F4 if you want to retain autofocus. Otherwise switch to manual focus. But I've found the autofocus will work with slower lenses in bright situations.
The Tamron 1.4x Pz-AF MC4 (4 element) t/c is excellent value for the price. That's the one Pentax users are universally happy with.
The Tamron 2x Pz-AF BBAR MC7 (coated, 7 element) t/c is the best bet if you want to go to 2x. It is also excellent value for the money.
01-16-2007, 06:48 PM   #8
roentarre's Avatar
I think the maximum aperture for AF in a SLR body with teleconverter is f5.6
The only exception to the rule is bigma (sigma 50-500 mm) where autofocus is possible at f6.3 because the lens sends "different signal" of f5.6 instead of true figure to the SLR body to allow AF.
01-17-2007, 05:30 AM   #9
cool, where can i get that one, I haven't seen it offered anywhere
01-17-2007, 05:43 AM   #10
roentarre's Avatar
Bhphoto sells it for 49 dollars.
Tamron 1.4X does compromise the image sharpness to a degree as most do. I left mine on the shelf ever since I had acquired this teleconverter.
It is a cheap stuff that you can try and see how it goes...
01-17-2007, 07:30 AM   #11
roy
roy's Avatar
i posted over in the post photo forum some shots with my 2Xmc4. they looked pretty good. i have never had good luck with zooms tho.
k-mount, pentax lens, slr lens, teleconverters
teleconverters ACHEBONE Ask B&H Photo! 10 10-30-2010 05:46 AM
Teleconverters GingeM Pentax SLR Lens Discussion 7 03-29-2010 04:20 AM
Teleconverters Reportage Pentax SLR Lens Discussion 7 01-15-2010 10:39 AM
About S and L teleconverters Zebooka Pentax SLR Lens Discussion 8 01-03-2010 07:16 AM
teleconverters bugman Pentax DSLR Discussion 4 11-16-2009 10:54 AM
All times are GMT -7. The time now is 12:15 PM. | See also: NikonForums.com, part of our network of photo forums!
