09-07-2013, 08:00 PM   #1
Question about DA35 2.4 lens
Since this lens extends slightly at certain focal lengths and the zoom (EDIT- focus) ring cannot be manually operated when in autofocus mode, is there a camera setting that will return the lens to its minimum length when powered off? I feel like the lens would be more secure in storage in the unextended position.
09-07-2013, 08:26 PM   #2
QuoteOriginally posted by Richjac Quote
Since this lens extends slightly at certain focal lengths and the zoom ring cannot be manually operated when in autofocus mode, is there a camera setting that will return the lens to its minimum length when powered off? I feel like the lens would be more secure in storage in the unextended position.
I'm kind of anal about this (and other lenses), especially since it's a tight fit in my camera bag. I've found it easiest to just hold down the lens release button to disengage the AF screw and then turn the focus ring to infinity. You could also switch to MF if your camera has that option, but that's slower and it's easy to forget to switch it back. Hope that helps!
EDIT: realized I didn't answer the actual question! So: as far as I know there's no camera setting that allows this, but you can use the workaround above. After a while it's pretty routine.
--Steve
09-07-2013, 08:27 PM   #3
manacho2005's Avatar
Pop the cap on and hit the AF. Mine always sucks in to infinity.
09-07-2013, 08:33 PM   #4
nparsons13's Avatar
Just focus on a distant object before you turn it off. That will pull it in.
09-07-2013, 11:03 PM   #5
Are you talking about a different lens? The 35mm isn't a zoom lens. And no, there is no lens retraction; that feature was discontinued when Pentax stopped making power zoom lenses.
09-08-2013, 02:05 AM   #6
rayallen's Avatar
Location: Forresters Beach, Central Coast, NSW, Australia
I think he meant the focus ring.
09-08-2013, 03:09 AM   #7
Yes I meant the focus ring of course. Thanks everyone for the tips.
09-08-2013, 05:53 AM   #8
Na Horuk's Avatar
Yes, you can switch to MF and focus to infinity. That should be the lens at its smallest.
Some lenses have internal focusing and they don't change size. Similarly for zoom lenses.
But the DA 35mm is so small I don't think you save much space by focusing it to its smallest length. I also don't think the lens is vulnerable if its "extended"
k-mount, lens, pentax lens, slr lens
DA35 2.4 vs FA50 1.7 chesebert Pentax SLR Lens Discussion 21 06-05-2013 07:46 AM
DA35 2.4 vs sub 100 vintage 24mm Talanath Pentax SLR Lens Discussion 20 06-04-2012 01:25 AM
DA35/2.4 ~ What about a 16 or 17 wide angle version? lightbulb Pentax SLR Lens Discussion 18 03-12-2012 08:44 AM
Question about Macro F1:4 50mm Lens Opahujo Pentax SLR Lens Discussion 5 11-27-2009 08:37 AM
Question about DA70/2.4 Jonas B Pentax SLR Lens Discussion 10 05-11-2007 06:44 PM
All times are GMT -7. The time now is 11:57 AM. | See also: NikonForums.com, part of our network of photo forums!
