09-12-2013, 04:01 AM   #1
Pentax DA lens to use on Nikon /Nex
Hi,
I like Pentax glasses and start using some of Tak glass on Nikon D7100/Nex5 as manual focus lens . Focus to infinity is an issue with adapter with glass since it degrade the picture quality.
I have not able to solve that issue but now I have two questions need helping with
1/- I am interest in one of Pentax DA 70mm and plan to buy for using in Nikon/Nex.
Is there any special about DA version which stop me to use on Nikon/Nex via adapter?
2/-In the long run, I might have to get Pentax camera. Since Pentax have several K, M mount - which one I need to get since I have several lens in K & M mount version . Do Pentax have Full Frame camera?
Thanks in advance
09-12-2013, 05:46 AM   #2
QuoteOriginally posted by louis_t1 Quote
Hi
Welcome to the forum.
The lack of aperture ring may be an issue.
The current DSLR lineup is K500, K50, K5 II, K5 IIs.
There is also the K-01 mirrorless.
That is a touchy question here!
At the moment, if you want a Pentax "Full Frame" 24x36mm camera,
it will have to use film.
If you want Pentax digital with a larger sensor than APS-C,
there's the 645D, but that won't take K-mount lenses.
09-12-2013, 05:54 AM   #3
Thanks lytrytyr for a quick answer. WIll check out these recommend DSLRs
09-12-2013, 06:34 AM   #4
VisualDarkness's Avatar
As long as the adapter can control the aperture there's no problem, otherwise go with lenses with a ring. Why only DA lenses? Often the older ones have much better focusing rings for MF.
The DA70/2.4 is a wonderful lens!
09-16-2013, 05:53 AM   #5
Could Pentax A len used on Nikon body ? if anyone know please let me know this
09-16-2013, 06:19 AM   #6
boriscleto's Avatar
If you don't want infinity focus, or are willing to use an optically corrected adapter, then yes. I'm pretty sure the light meter won't work either.
09-16-2013, 06:25 AM   #7
QuoteOriginally posted by boriscleto Quote
Thks boriscleto. So I am plan to get Pentax A 300mm F4 - is it K mount or M mount? I only see they have two kind of adapters
09-16-2013, 06:46 AM   #8
boriscleto's Avatar
M mount is for Leica rangefinders. M42 is called Pentax thread mount in the US (or Universal thread mount or Praktica thread mount).
All Pentax slr lenses made after 1975 are K mount.
Pentax K-Mount Lenses Explained: The differences between various Pentax lens series
09-16-2013, 06:54 AM   #9
Thks boriscleto - It make more sense to me now.
Cheers
camera, da, focus, glass, k-mount, lens, nikon, pentax, pentax lens, slr lens, version
Adapter to use pentax lenses on nikon mount zmohie Pentax SLR Lens Discussion 6 03-11-2013 01:42 PM
Lens adapter to use non Pentax lenses on 6x7 Surlysteve Pentax Medium Format 8 03-12-2012 06:30 AM
Question on lens converters Nikon to Pentax BNBPhoto Pentax SLR Lens Discussion 6 02-28-2012 01:22 PM
Pentax lens to NEX 7 adapter? durr3 Pentax SLR Lens Discussion 3 10-13-2011 11:15 AM
All times are GMT -7. The time now is 05:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
