09-16-2013, 10:24 AM   #16
Then 99% of the time, you have to use the EV button to change your Exposure Value, there's no other way to do it.
I'm with normhead on this one. I use EV constantly. In fact I've got it programmed to the front wheel in AV mode. I find it especially useful when doing back lit shots where proper exposure is difficult to get w/o blowing highlights.
NaCl(it's my best friend under those conditions)H2O
09-16-2013, 10:30 AM   #17
richardstringer's Avatar
Yeah but as far as I can see, there's no difference between using exposure compensation and just changing the shutter speed to get the correct exposure because adjusting the exposure compensation does exactly the same thing in AV mode.
09-16-2013, 10:37 AM   #18
normhead's Avatar
QuoteOriginally posted by richardstringer Quote
You need to try this out. Set your exposure in AV, take an exposure, set the EV button to -1, take an exposure, see if the two exposures are the same. Do the same thing by changing changing yoru exposure with the Aperture dial. See what happens, look at the four pictures. Only one will be darker than the others.
You cannot adjust the shutter speed in AV mode. You can adjust the Aperture. The camera adjusts the shutter speed to maintain the EV value it thinks is the correct one. If the selected EV value is incorrect, (because it' backlit, because the sun or some other light is shining into the camera, because the angle of the lens to the camera is fooling the meter), because the camera assumes you want the median value when in fact you want the average value as the centre weight point, for any number of reasons, you may have to adjust the EV.
EV (exposure value)= aperture x shutter.
Changing the aperture dial in AV changes the shutter in sync. +1 stop aperture will = -1 stop shutter speed. That will produce exactly the same EV.
Anyway, enough of me going on about it. If you don't want to experiment with the EV button, then don't, it's no sweat off my back.
09-16-2013, 11:16 AM   #19
Wo hold on mate, I never said i'm not gonnna experiement did I? I will, i'll take four photos and see the difference between using the EV and not using it.
17-50mm, 18-55mm, k-mount, kit, lens, pentax lens, shutter, slr lens, tamron
Sigma 17-50mm F2.8 vs Tamron 17-50mm and Pentax DA* 16-50mm Adam Pentax SLR Lens Discussion 89 12-28-2014 07:28 PM
K-5 with Sigma 17-70 vs 17-50 vs Pentax 18-135 vs Sigma 18-250 dr_romix Pentax K-5 20 08-25-2012 07:19 AM
Tamron 17-50 (300) VS. Sigma 17-70 f4.5(380) VS. DA 18-135 (450) Tomm Pentax SLR Lens Discussion 23 03-25-2012 10:01 PM
Pentax K-5 with 18-55mm kit lens vs. with Sigma 17-70mm OS HSM Macro? lukelbd Pentax DSLR Discussion 5 11-19-2011 11:44 AM
Tamron 17-50mm vs Sigma 18-50 robcap13 Pentax SLR Lens Discussion 2 04-01-2009 11:50 AM
All times are GMT -7. The time now is 02:40 PM. | See also: NikonForums.com, part of our network of photo forums!
