03-26-2008, 08:41 PM   #1
Focal Length from EXIF
Just an observation, not an issue.
I was looking at the EXIF data from a photo I just did with my new M 135 and under Focal length equals 200mm and Focal Length in 35mm equals 300mm. ...incorrect, it should state 135mm and 200mm respectively.
For comparison I looked at the EXIF from photos taken with my M 85 and it read Focal length equals 85mm and Focal Length in 35mm equals 127mm ...this is correct. I also check the EXIF from my previous DA 18-250. It was correct.
I guess the M135 does not write the correct Focal Length in EXIF, at least on the K100D Super. Can anyone confirm this whether on the same body or a different Pentax?
03-27-2008, 01:10 AM   #2
NO M-lens will transmit focal length data to the body. The focal length recorded is what you have told the body to use for the shake reduction to be able to work.
03-27-2008, 05:40 AM   #3
QuoteOriginally posted by SupremeMoFo Quote
Thanks for that info, I won't have thoght of that. I remember now setting the SR at 200.
03-27-2008, 06:13 AM   #4
QuoteOriginally posted by metalfab Quote
If your lens is 135mm, why do you set the SR to 200mm ?
The focal length you put in SR does not need to be multiplied by 1.5, if that is what you thought. SR needs the actual physical focal length. not 35mm equivalent.
200mm, 35mm, exif, k-mount, length, pentax lens, slr lens
focal length ewig Troubleshooting and Beginner Help 11 07-23-2010 09:32 PM
focal length landscaped1 Troubleshooting and Beginner Help 48 05-05-2010 03:04 PM
K7 is 1.5 x focal length? rdrum76 Pentax DSLR Discussion 18 06-30-2009 08:30 AM
PnS camera's focal length do not tally with exif? raider Pentax Compact Cameras 9 02-12-2009 12:57 AM
Focal Length Jimsi777 Pentax SLR Lens Discussion 2 11-09-2007 06:46 PM
All times are GMT -7. The time now is 11:10 PM. | See also: NikonForums.com, part of our network of photo forums!
