03-27-2008, 12:44 AM   #1
FA 50/1.4 aperture
Hi.
I have a question about FA 50/1.4. When it's wide open (1.4) and DOF preview (not digital) is pressed the aperture blades retracts a little bit. Is that a normal behaviuor?
Thanks and sorry for my bad english.
03-27-2008, 01:05 AM   #2
Yes - f1.4 is excessive for the AF sensors in well lit conditions and makes AF less accurate.
Welcome to the forums
03-27-2008, 01:40 AM   #3
blende8's Avatar
QuoteOriginally posted by voltigore Quote
Hi.
No. This should not be.
Perhaps the diaphragm actuator is a little bent?
But if it is only very little I would not worry much about it.
03-27-2008, 11:25 AM   #4
Thank you all for the replies.
blende8, the actuator on the lens looks fine.
Now I tested it with setting the aperture (1.4) from the lens ring and using stoped down metering with AE-L button. I can hear "zip" sound but aperture blades in this case are not visible as it shoud be.
When I set the lens on A and aperture 1.4 from the body and pres DOF preview the blades retract a little bit as I said in the first post. My concern is that this happens on shooting too.
The body is k100d super.
Please, can someone with FA 50/1,4 confirm this? Thanks.
Sorry for my english.
03-28-2008, 12:22 AM   #5
So no one can atach his 50/1,4 to check?
03-28-2008, 08:30 AM   #6
blende8's Avatar
My copy isn't doing this.
03-28-2008, 09:13 AM   #7
I just tried this on my K10D FA50mm @ F1.4 aperture ring set to A.
DOF Preview does retract the aperture blades a little approx 2-3 millimeter.
On shooting its either too fast to to see it, or their is little or no movement at all.
Sorry I could'nt be of more help.
Cheers
Del
03-28-2008, 09:15 AM   #8
Miserere's Avatar
Just for you, I attached my FA 50mm and tested the DoF preview. Mine doesn't stop down a little, it stops down completely! However, it shoots correctly when set to f/1.4, so my guess as to why it does that for the DoF preview is as good as anyone's.
03-28-2008, 09:59 AM   #9
I appreciate your help!
One copy retracts, another doesn't... Looks like those lenses have character
03-29-2008, 10:49 AM   #10
Groundloop's Avatar
Voltigore,
I just picked up an FA 50 1.4 today, and when the aperture ring is set to 'A', mine also stops down slightly when using the DOF lever. If I set the aperture to 1.4 manually, it doesn't stop down at all. Basically it behaves the same as yours. I haven't seen any difference in exposure between setting the aperture via the E dial or the aperture ring.
aperture, fa, k-mount, pentax lens, slr lens
Aperture 3 the swede Digital Processing, Software, and Printing 18 08-30-2010 04:25 AM
Need help with aperture rogue9607 Pentax SLR Lens Discussion 2 02-27-2010 09:14 PM
Constant Aperture vs Variable Aperture Netsoft Pentax SLR Lens Discussion 13 01-11-2010 07:29 AM
Use of Aperture-Ring 43mm/1.9 -> no aperture data Deimo Pentax SLR Lens Discussion 7 06-24-2009 03:25 PM
Hello: I am aperture aperture_09 Welcomes and Introductions 2 03-19-2009 04:44 PM
All times are GMT -7. The time now is 06:16 PM. | See also: NikonForums.com, part of our network of photo forums!
