03-27-2008, 01:36 AM   #1
Arsat MC 35mm Tilt & Shift for Pentax K mount?
Does anyone have this lens? If so, how is it? The search function brought up a few T&S threads, but most of the discussion seems to revolve around the Arax. I've been thinking about getting a perspective control lens for a while, and this is 1/2 the cost of the Hartblei Super rotater at a similar focal length.
03-27-2008, 08:21 AM   #2
aegisphan's Avatar
The Arax and Arsat are the same. However, I think you're better off going with a tilt adapter then get the shift lens for P6 system. That way, you'll have the whole P6 lenses offering to add to your tilt/shift collection.
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/21389-what-s-y...ns-pentax.html
03-27-2008, 05:24 PM   #3
QuoteOriginally posted by aegisphan Quote
Ah, that would explain why they look alike. At first I thought that they were both copies of someone else's design made by different manufacturers (Arsat vs. Arax).
What T&S adapter works well and how are the Pentacon 6 lenses?
03-27-2008, 06:08 PM   #4
aegisphan's Avatar
The Arax/Arsat Tilt/Shift (either or, not both) adapter only works with Pentacon 6 mount lens. These lenses are old but they're among the best price/performance. I got myself a Zeiss Flektogon 50/4 for like $80, and it competes quite well against other wide angle lens. Arsat lenses for P6 are no slouch either. You can take a look at the Vega 90's shots from the provided link above. I figure if I buy the tilt adapter, then I buy the Arsat 55 Shift for P6, I have a T/S lens for less than the 35mm T/S.
If you want only one focal with the ability to T/S, then I guess the 35mm is better (being wider). But if you plan to do this with various focals, then the adapter would be more versatile, cheaper.
k-mount, lens, pentax lens, shift for pentax, slr lens
Will Arax/Arsat 35mm T/S physically mount on Pentax? MrA Pentax SLR Lens Discussion 3 09-25-2010 11:41 PM
So why didn't anyone else want this lens? PCS ARSAT H Shift Lens 35mm f/2.8 m8o Pentax SLR Lens Discussion 26 03-19-2010 04:07 PM
For Sale - Sold: DA* 16-50mm 2.8 for 35mm Tilt/Shift Votesh Sold Items 1 02-10-2009 11:01 PM
35mm and 80mm tilt shift lens for Pentax High Roads Photo Photographic Technique 6 09-07-2008 03:41 AM
All times are GMT -7. The time now is 04:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
