Originally posted by SpecialK You can go to the fisheye thread and compare images there.
Fisheye Fever Club -- Flaunt your fisheye photos!
1+
Look carefully at the photos there. A few random comments:
- You will note that the Pentax 10-17 is prone to very pronounced purple fringing. This a characteristic of fisheyes, but the 10-17 seems to be somewhat worse.
- A stand-out lens in the fisheye club is the Sigma 15mm (just my opinion)
- I own the Zenitar 16/2.8 and am quite fond of the lens. It is equally fishy on FF (35mm) and APS-C, but the crop factor tends to calm the curves. I have taken some very fishy photos with the Zen on both formats. Much depends on camera angle, perspective, and choice of subjects.
- I also own the Samyang 8/3.5. It is very wide, but the 8mm focal length makes viewfinder focus (even with split image screens) almost impossible. The general rule of thumb is to zone focus at 5' @ f/8 to provide acceptable focus from 12.5" to infinity. It is quite fishy, but in a different way than most fisheyes due to its near-stereographic projection which reduces stretching at the margins.
- The Samyang has "A" contacts allowing all exposure modes on Pentax dSLRs. The Zenitar has the standard K-mount and is limited to M mode.
- Both the Samyang and the Zenitar are more flare resistant than one would expect an both have excellent contrast.
- The Zenitar is very compact. The Samyang, somewhat less so, though still not huge.
Both the Samyang and the Zenitar are very capable optics, though not so much so wide open. I have found the Zenitar to be more useful for a wider range of subjects due to its longer focal length.
Zenitar examples (both 35mm film and APS-C)
HERE.
Samyang examples (not as many, but all APS-C)
HERE.
And for a most unusual series of self-portraits with the Zenitar, you should definitely look at forum member Rense's "
Single in September" series, all of which were taken with the Zenitar.
BTW...both my Zenitar and Samyang required adjustment to the focus ring for distance calibration. Not hard, but a pain to have to do.
