09-22-2013, 05:37 PM   #1
Fat Albert's Avatar
Swapping out the plastic mount on a DA 35/2.4?
I've got a truly awful F 35-80 that I'm going to take apart so I can see how it's put together. Is transferring the mount to my 35 as simple as I think it is? Has anybody successfully attempted this? I searched the archives, but didn't find any threads that show results.
09-22-2013, 07:20 PM   #2
Just1MoreDave's Avatar
This recent post indicates you might have trouble:
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/236756-transpl...ml#post2506650
It might be something you can work around. The mounts are meant to do the same job, but a lot of manufacturing changes happen over 25 years.
09-22-2013, 09:20 PM   #3
EarlVonTapia's Avatar
QuoteOriginally posted by Fat Albert Quote
I tried putting the mount from my F 35-105 onto a DA 35 2.4. It did not work. There was a plastic piece inside the ring that extended inward that prevented the mount from sitting cleanly on the DA 35 2.4.
That being said, someone with power tool skills could probably cut that piece off to make it fit. Or, if you have another F series mount, like from a prime lens, that might work off the bat.
Anyways, taking the mounts off is pretty simple. Just put a piece of tape over the contacts so that the contact pins don't spring away into your carpet and be lost forever.
09-22-2013, 11:44 PM   #4
Get the right part
Or you could call pentax at their 800-877-0155 number to get the right part that is the right thickness so your lens will focus properly. Probably the part costs less then ten bucks and will be less headache. Rarely are such things interchangable.
09-23-2013, 07:02 AM   #5
Fat Albert's Avatar
QuoteOriginally posted by pentaxus Quote
If you read my OP, you'd know that my aim is not to replace the plastic mount--it's taking apart an old lens.
09-27-2013, 12:59 PM   #6
not sure that you can just take any Penatx lens mount and replace it - just looking at the part. Lenses require different amount of shimming etc, so there is more to it than simply replacing a single piece like a "mount". Many funny thing can happen and you may lose your 35 mm lens.
k-mount, mount, pentax lens, slr lens
Replacing DA-L 35/2.4 Mount Verglace Pentax SLR Lens Discussion 4 06-28-2011 08:13 PM
DA 35mm F2.4 - Plastic Mount Question DaveHolmes Pentax SLR Lens Discussion 11 05-03-2011 04:18 AM
So a full plastic 35/2.4 is available at Nikkor 35/1.8 price? kales Pentax SLR Lens Discussion 79 01-31-2011 08:25 PM
Swapping out Minolta mount with same model lens hangu Pentax SLR Lens Discussion 3 04-16-2010 12:46 PM
All times are GMT -7. The time now is 07:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
