03-27-2008, 11:49 AM   #1
hinman's Avatar
Jupiter9 85mm f/2.0 Test Shots
I bought this a while ago from my good friend igowerf (James) and the lens is in pristine condition. I finally made a chance to test the lens. It is manual focus in M42 mount and it is not easy to use for me especially with my kids moving, the manual focus get me in trouble with focusing problems. But the lens seems to go softer in wide open aperture but the color and bokeh seems pleasant.
Jupiter9 85mm f/2.0 Test Shots - Hin's Tech Corner
All indoor test shots in f/2.0 and ISO 400 hand held
f/2.0 in iso 200
f/? in iso 200 (likely f/4.0)
f/? in iso 200 (likely f/8.0)
A while ago, there is a thread on 'lens war with 77mm limited' and when I use the lens, I wish I have the AF but for the price of < $100, I can't complain.
Thanks,
Hin
03-27-2008, 11:57 AM   #2
nice photos hinman! i've learned a lot reading the various articles from your blog
this lens seems like nice budget alternative to the 77 or *85
but i remember reading that the use of this lens is different from any other lens, but not sure why??
anyone know if this lens is available in K-mount and what price new?
03-27-2008, 12:20 PM   #3
hinman's Avatar
QuoteOriginally posted by k100d Quote
Thanks for the comments. There are few reasons that the lens are difficult to use. The aperture ring is in the very front of the lens and one has to look at the ring in order to know what aperture to turn to. And there is another ring next to the aperture ring that allows one to stop down manually. And the setup requires to turn the extra ring to wide open aperture in order change the aperture, making it awkward in changing apertures. But once I used it a few times, I manage to get over the cumbersome feeling and get to like the lens for what it is. I am running low budget for gear and I have bigger stamina for annoyance.
And the focusing is a bit stiff on my copy of the lens and focusing is prone to turn the lens loose from the screw mount adapter -- that is something I am yet to overcome.
Though the few negatives, my overall impressions has been positive. On previous thread on lens war with 77mm limited, there is link to get new copy for about $120 and the latest has the coating that will work better with flare. As far as I know, even the new one is in M42 mount. James has sold me the lens with a matching len hood and the darn thing looks so cool together like a machine gun in disguise, very well built.
aperture ring and stop down ring in front
Thanks,
Hin
03-27-2008, 12:41 PM   #4
Nice pictures!!
Where did James get his hood? My Jupiter-9 should be arriving any day from Russia and I think I will be needing a hood. I was interested to read your comments regarding the pre-set aperture. I am a bit concerned that I will miss some good shots while I am fumbling with the pre-set ring!
03-27-2008, 01:22 PM   #5
Fritz's Avatar
Those turned out great Hin. Even though it's a little more work having to manually adjust the focus and aperature, the results speak for themselves!
03-27-2008, 01:34 PM   #6
Hey Hin!
Sorry You cropped You last shot on the left side (either in PP or framing)... Does Your copy have additional labels like "MS JUPITER-9" and "2/85" on it- if so this is IMHO a coated version (and somehow better than recent RU ones :-) This was my 3rd copy of all variations and I converted it to permanent K-mount via fixed adapter. Very funny and capable lens for me!
It seems that I have no uploaded pics with it but about 50% of my framed ones are with it- film or digital and I must say that I am an addict of high blade count lenses (Jupiter has at least 15...)- and this makes the rendering of OOF area... (and yep I know that this one is pre-WWII Zeiss one).
Best and hope You like this highly creative one, JR
03-27-2008, 02:14 PM   #7
hinman's Avatar
QuoteOriginally posted by Reps Quote
Hi Reps, I remember you from the Casio forum. My version of Jupiter9 does not have the coating. Mine is the old one. And here is the picture that I borrow from my friend igowerf (James)
I did try to convert my Jupiter 9 to a permanent K mount but without success. The drilled hole on the lens base is right a the edge with the locking pin and hence not strong enough to hold the locking pin from the K body. I have a write up on how I convert another M42 lens to K mount here:
How to convert Pentax M42 to K mount lens - Hin's Tech Corner
Due to the stiffness of the focusing ring, I have resolved to use the genuine m42 adapter to work with my jupiter9 instead. I may try to drill another hole on the AF/MF switch location and see if two drilled holes on the lens base can secure the lens in place.
Thanks,
Hin
03-27-2008, 02:19 PM   #8
hinman's Avatar
Nice pictures!!
I don't quite know about the whereabout to get the lens hood. As for the pre-set aperture ring, don't worry too much about it. After one day of use, I have overcome the fumbling. Besides, I learn it from James that I always preset the lens aperture to roughly around f/4.0 to f/8.0. If your copy is the old version without coating, a lens hood is very much recommended to buy with the lens. I have another SuperTakumar 105mm f/2.8 that share similar lens hood on 49mm size and my lens hood ends up with a front cap of 58mm size
Thanks,
Hin
03-27-2008, 02:21 PM   #9
Canada_Rockies's Avatar
Nice pictures!!
Set the click stop ring for the exposure you want or need. The left hand holds the lens with one finger on the "loose" ring, and opens and closes it with a quick flick of the finger. My left ring finger worked on my Takumars. The rest of it is just practicing so that you get into the habit of flicking the actual aperture closed against the preset just as you shoot, and immediately flick it back wide open. Focus, flick closed, snap shutter, flick open, and repeat.
03-27-2008, 02:22 PM   #10
hinman's Avatar
QuoteOriginally posted by Fritz Quote
Thanks for the kind words. I think the original poster in another thread on 'lens war with 77mm limited" does a much better job in taking photos with this lens. My pictures are way soft as I have some mistakes on my focusing.
Hin
03-27-2008, 06:30 PM   #11
hinman's Avatar
QuoteOriginally posted by Canada_Rockies Quote
Thanks for the explanation and techniques to use the lens. I have a photo of the lens with the hood on. The lens hood is on 49mm and a cover for the lens hood is either at 55mm or 58mm
The drilled hole doesn't secure the lens in place.
I failed in the 1st attempt, will try again with 2nd hole on AF/MF switch
few more test shots
03-27-2008, 07:03 PM   #12
Steinback's Avatar
Reading through this, I was trying to think of other ways to permenantly or semi-permenantly attach a K to M42 adaptor to a lens without machining. Do you know of anybody who has tried loctite (or a similar thread locking compound) on the lens threads? I've used both removable and permanent strength loctite on automotive projects, and both are simple to use and do a good job of holding threaded metal parts together. On the parts I've dealt with you can usually break the removable loctite's bond with a wrench, and you need to apply heat (usually with a torch) to break the permanently bonded parts loose from each other.
03-27-2008, 07:57 PM   #13
I thought about something similar, but then it occurred to me that something has to have a hole so that the lens locks into place on the camera body. That or you have to rig something to be able to get to the locking spring on the adapter while the lens is on it.
03-27-2008, 09:41 PM   #14
Steinback's Avatar
Xixco, I see the problem with my suggestion now that you've pointed it out. I have an M42-K adaptor, but I haven't used it much - I bought it so that I could borrow lenses from my Dad when I'm at home and I don't actually have any M42 lenses with me right now to experiment on. I guess I'll take another look at the problem once I find a lens to play with, but I can't think of any way to avoid permanently modifying a lens right now either.
03-28-2008, 04:14 AM   #15
Yes, the Jupiter 9 is an amazing miracle of German engineering "acquired" by the Soviets during WWII and put to wonderful use.
This is one of those lenses that has such a distinct quality to the bokeh (in no small part to the 16-bladed aperture) that I can almost identify photos taken with this lens on sight.
Granted, it's not the world's most practical lens on a modern Pentax camera, but it's still a great piece of glass.
I don't use my Jupiter 9 as much now that I have the DA 70mm f/2.4 Limited. I also have a friend who can lend me a 77 Limited when I need it, but I find the 70 handles everything I used to use the Jupiter 9 for on a regular basis.
Here's a snapshot I took with my very old, early production Jupiter 9 a while back:
The only thing you have to watch out for with the Jupiter 9 lenses is that many have less-than stellar Soviet-era workmanship and most of the older lenses have failed at some point and either been disassembled and put back together or they're being sold on ebay while they're still broken.
My particular Jupiter 9 shows tell-tale common signs of amateur repair work (oily aperture blades and a reversed aperture dial). However, it still produces great photos and I paid next to nothing for it.
85mm, f/2.0, focus, iso, jupiter9, k-mount, lens, pentax lens, shots, slr lens, test
People My Son/Vivatar 85mm @ 1.8 - TEST - arbib Photo Critique 4 10-09-2010 10:06 PM
French Test of 85mm fourmiX Pentax SLR Lens Discussion 22 02-17-2010 12:54 PM
Rokinon MF 85mm f/1.4 first test jogiba Pentax SLR Lens Discussion 10 06-26-2009 04:50 PM
FA* 85mm F1.4 - sample shots legacyb4 Pentax SLR Lens Discussion 45 02-18-2009 10:56 AM
All times are GMT -7. The time now is 09:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
