09-26-2013, 06:45 AM   #1
aleonx3's Avatar
Pentax A 501.4 pin not recognized by k-5
I have recently acquired a nice Pentax-A 50f1.4 lens. The "A" pin is actually recessed below the mounting plate so when mounted on my k-5, it does not recognize it as "A" lens. Is this something that I can easily fix or should I send it Eric to have it fixed. Thanks in advance for your help...
09-26-2013, 06:57 AM - 1 Like   #2
Giveaway winner!
MysteryOnion's Avatar
QuoteOriginally posted by aleonx3 Quote
"...A" pin is actually recessed below the mounting plate...
sounds like the tiny spring under it is missing?
09-26-2013, 07:46 AM   #3
aleonx3's Avatar
QuoteOriginally posted by MysteryOnion Quote
@MysteryOnion, is this easy to find out...or is this too risky. Thanks...
09-26-2013, 07:47 AM   #4
Not a Number's Avatar
Is this when the aperture ring is set to "A"?
09-26-2013, 08:02 AM   #5
aleonx3's Avatar
Yes... when the ring is set to "A"; also when the camera is turned on, it asks to input the focal length...
09-26-2013, 08:33 AM   #6
Master of the obvious
savoche's Avatar
It will do that anyway, even with the pin in place, so that's normal.
Can't help you with the pin, though, sorry.
09-26-2013, 09:17 AM - 1 Like   #7
As suggested earlier perhaps the spring is missing or things are a bit gummed up. Try moistening a cotton swab with a little rubbing alcohol or lighter fluid and dab a tiny amount on the pin and jiggle the ring while depressing the "A" button. You only want a little amount as you don't want the fluid flowing into the rest of the works.
Perhaps a previous owner disassembled the lens for one reason or another and lost the spring or incorrectly re-assembled it. Does the aperture ring click-stop when off the "A" lock? The little dented ball bearing is the most commonly lost part.
09-26-2013, 09:28 AM   #8
aleonx3's Avatar
As suggested earlier perhaps the spring is missing or things are a bit gummed up. Try moistening a cotton swap with a little rubbing alcohol or lighter fluid and dab a tiny amount on the pin and jiggle the ring while depressing the "A" button. You only want a little amount as you don't want the fluid flowing into the rest of the works.
Thanks for the suggestion with lighter fluid or rubbing alcohol, I will try that before taking it apart. The previous owner had this lens on the K1000 camera (may be the spring get stuck a little as there is no A contact on the k1000). On the whole, the lens looks in very good condition. The aperture ring works perfect with clicks and proper closer of the aperture blades.
I have another A 50f2.0 in similar situation, may be I will try to take apart that one first.
09-26-2013, 01:25 PM   #9
If the design is similar to the f/1.7 then you should be able to remove the pin assembly without removing (and risk losing the ball bearing) the aperture ring. It might just need a bit of grease in there. On my f/1.7 this assembly is four pieces: a plate that rests on the camera, a sort of clip, small spring and the pin itself. The pin, clip and spring are so tiny it is a major pain re-assembling them if they fall apart. Which they do easily when removed from the lens.
Refer to the photos in this thread:
https://www.pentaxforums.com/forums/maintenance-repair-articles/88051-pentax-...ng-repair.html
I am in the process of reassembling my f/1.7 having done this repair. I'm waiting for the dental acrylic to cure that I needed to patch one of the screw holes when the threads stripped out (not drilled deep enough). I'm going to try holding in the ball bearing with a bit of sticky cellophane tape and a strip of paper over the two clips. These can be pulled out after the ring is in place. It might make things simpler.
09-26-2013, 06:17 PM   #10
On my A 1.4 there is a little button that you have to push on the aperture ring to get it to lock into A position. Push and turn. If it is locked properly the aperture ring doesn't turn.
09-26-2013, 06:24 PM   #11
aleonx3's Avatar
Thanks, I will take a closer look at that. I also have the A 50f1.7 and 50f2.0. I noticed that they are slightly different once I opened it up. Likewise for the A50f1.4. I need to carefully plan out what to do first...
09-26-2013, 06:27 PM   #12
aleonx3's Avatar
QuoteOriginally posted by derekkite Quote
Yes.. thanks, I confirm that on the other lenses as well as the A50f1.4. The only thing is: once the Aperture is set to the 'A' position, the A pin on the lens mount should be up slightly (it happens on the other lenses), but on this A50f1.4, it stays flush to the mount. So, apparently the A assemble spring is either missing or non-functioning.
09-26-2013, 06:46 PM   #13
hks_kansei's Avatar
Jiggle it about a bit before opening the lens up.
The pin is an absolute arse to work with, and to seat correctly again when re-assembling.
If you can avoid having to touch it, do so. (I opened up a 28mm A lens, the pin and spring took me about 5 hours to correctly re-seat. (It's a poor design)
Just try repeatedly moving from A to F22 at the same time as pressing on the A contact pin with a fingertip or a wooden toothpick (won't mark it like metal)
That fixed the issue of my 50mm1.7.
If that doesn't work, then try the cotton bud with cleaner on it.
09-27-2013, 09:49 AM   #14
aleonx3's Avatar
I finally succeeded to reseat the spring in the A pin. Now, it works the same way as it should. I am quite surprised that it allows me to step up the aperture from 1.4, 1.6 and 1.8, 2.0 increment, which is great!! I spent many hours trying different things, the spring and pin-cap was so tiny that it is difficult to handle. I also lost a few springs (thanks to the warnings but still do), I sabotaged a broken FA28-70 f4 lens to salvage extra springs.
Thanks to everyone on this thread for all the suggestions, they were all very helpful indeed and let me focus on the part to be fixed.
I suppose we can close this thread now..
k-5, k-mount, lens, pentax lens, pin, slr lens
Converting K/M lenses by adding an A pin? Vranx Pentax SLR Lens Discussion 57 01-21-2013 07:12 AM
Pentax K-x lens not recognized/others malfunctions. steezylistic Troubleshooting and Beginner Help 13 01-05-2012 08:23 PM
Sigma 10-20mm/4-5.6 not recognized by K-5 lockheed Pentax K-5 & K-5 II 14 10-31-2011 08:27 AM
K20D Not Recognized by Remote Assistance LeeHolliday Pentax SLR Lens Discussion 4 08-25-2009 01:15 PM
Pentax-A 28-80 3.5-4.5 but f3.5 not recognized? imtheguy Pentax SLR Lens Discussion 8 08-10-2009 09:17 PM
All times are GMT -7. The time now is 01:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
