Originally posted by yusuf I had a Cimko made rebranded 135mm f2.8 which looked very similar, all engraving and M/A marks except for the chromed color ring. They were one of the Japanese manufacturer focused on the whitelabeled lens offering.
Thanks - always some direction to look into. The guy here :
Super Paragon ( Cimko ) 135mm f2.8 is showing off some nice photos taken with a Cimko manufactured lens.
Originally posted by elliott The rear construction seems to be very, very similar as well. I have a hard time believing that it could be just coincidence.
Well - these are similarities that cannot be ignored - I however also see a lot of differences - different coating color, difference in barrel, difference in MADE IN JAPAN lettering ( your one seems to be painted, on mine one is embossed/ engraved in the metal ), also the closest focusing distance tells me that the optical formula is probably different - not sure though since your shots doesn't clearly show what is a minimal focusing distance on your lens.
Originally posted by elliott It has been years, but if I had to guess it looks like maybe f5.6.
I will try to go out and shot something with flare in it tomorrow ( today we had a very dull day where I live ). Will use the same aperture to see if the lens can handle this bright light source similarly.
Originally posted by elliott I think it might be related to this one as well:
Beroflex auto 1:2.8 f=135mm
Exactly from that link you gave I found that related thread linked above, about a Cimko lens that shares some similarities with mine one.
Originally posted by thornburg Given all the factors others have stated, combined with the "001" serial number, I'm going to go along with the theory that this was either a demo model, or maybe a manufacturing run test.
Yeah, seems to be the case. And I agree - this is definitely quite unique lens.
Not only because of lack of branding - but also as it performs exceptionally well. I had a chance to play with it against a famous Pentacon electric "red" MC 135mm 2.8 which is owned by a friend of mine. Here is a photo of the two lenses. Pentacon is substantially larger and heavier ( about 100g. more ) and also has further minimal focusing distance at about 1.7m. I will post some results later tonight once I get them organised somehow.
Thanks to all for participating in this small researching !
