Originally posted by OniFactor how is it a push pull, without changing length? the push-pull's ive had (2 sigmas for Minolta Alpha mount), there were 2 barrels, one slid over the other, and changed the total length. does the pentax work any differently? it looks the same as the sigmas, since it has the aperture lines on the barrel, like the ones i've used..
The zoom/focus ring on the A 70-210/4 moves back and forth to zoom without changing the lens length. You have more barrel in front of the collar/ring and less behind and vice versa. The lens is an internally zooming lens. The mechanics are such that the ring moves some of the lens groups when pushed and pulled, and when it is turned it moves a different collection of lens elements (which may include some of the same elements as the zoom movement uses). In the case of the lens mentioned, the focus control does change the length of the lens slightly, so it is not internal focus.
Not all one touch lenses are internally zooming, nor are all two touch zooms internally zooming. An example is the DA* 16-50 which changes length as the focal length collar is turned. The 12-24 is shortest in the middle, as is the FA 24-90. An internally zooming lens is simply one where the last piece of glass towards the subject stays the same distance from the film plane while zooming. The lens designer must take into account a zillion variables. Sometimes the choices are different.
Are you perhaps trying to say that you prefer two touch to one touch? Separate collars for focus and zoom? I know I do, but the A 70-210/4 was far more attractive to me, at a premium of $10 over the F 70-210/4-5.6 two touch lens that was beside it in the showcase when I bought the lens. I'll take f/4 at 210 over f/5.6 any day of the week, including Sunday, even if I have to have a one touch zoom/focus collar. I find it annoying, but I like the optics, so I use the lens anyway.
