10-01-2013, 10:46 PM   #1
M42 Pentacon Auto 50mm f1.8 MC
Hi,
I have a Pentacon 50 1.8. It gives decent images so I believe it is worth cleaning because there are huge dust particules inside.
The front name tag ring is so stubborn. So I want to enter from the mount. Anyone has any experience? I would appreciate advices.
Murat
GT-I9300  Photo
10-02-2013, 12:39 AM   #2
I haven't had this particular one apart, but I've had a few similar 50s apart. There is no way to reach the front element from the rear, you can just reach the rear of the element that is in front of the aperture blades.
The aperture is in between the two concave elements.
What have you tried to use to remove the name ring?
10-02-2013, 10:29 PM   #3
pentacon 50 1,8
I tried with rubber gloves, some lens caps with rubber and a buthtub plug. Its very stubborn.....
10-02-2013, 10:38 PM   #4
What I have had luck with is rubber drawer liner material and some appropriately sized PVC pipe or similar thick wall tube.
Where exactly is the dust, directly behind the front element? If the worst of it is behind the 3rd element then going through the rear is a viable option, though tricky because you'll be removing the aperture.
10-02-2013, 11:56 PM   #5
QuoteOriginally posted by elliott Quote
I said "what the heck" and I opened it from behind.Removed the aperture blades and blew the dust away. Luckily there was nothing between the front elements. I think they were not dust but the metal coating peeled off the metal ring which the aperture blades sit on. Putting the blades wasnt a problem. And the rest of the actual dust was between the rear elements. It was 2 mimutes job to open it with a 10 dollars spenner wrench. And it is just like new now.
I was lucky this time.
Thanks for the feedback anyways.
Murat
Carl Zeiss Jena MC Pancolour f1.8 50mm M42 disco1111 Pentax SLR Lens Discussion 4 06-11-2013 08:12 PM
Pentacon Auto F1.8/50mm pentagor Pentax SLR Lens Discussion 10 01-11-2013 03:25 AM
For Sale - Sold: Carl Zeiss Jena MC Pancolar auto 80mm f1.8 M42 Mark Littlewood Sold Items 11 11-05-2011 05:28 AM
All times are GMT -7. The time now is 12:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
