Originally posted by robthebloke My advice would be to get a non-A 50mm. I've got the 50A, and it's a fab lens, but the metering on digital is a little wild. As a result, I usually just end up doing everything manually anyway (Hell, you'll only be buying it for 1.4 anyway, in which case the metering on the M version will be just as good as the A!). I recently bought the DA50 f1.8 simply because I wanted something a little bit more user friendly than the 50A. I suspect, that as an owner of the 50F 1.7, you'll be using that most often, with the f1.4 only coming out when you need the extra bokeh. My 2 cents....
Yes precisely my feelings. I love F 50mm 1.7 and am using it very often. 1.4 - which ever comes will come in when time allows to play with it as I know from other manual glass that to appreciate them one needs to have time.
Originally posted by Sagitta FWIW, I did this with the Pentax-M 50mm 1.4, wide open. Yea, it was sharpened in post to fix issues with the camera's sensor, but well... this was shot wide open on a camera with a damaged sensor.
Impressive - shame I won't be seeing this live any time soon - living in 10-milion city doesn't make things any darker at night .. anyway great to see what these old lenses still can do - can't wait to pick something finally.
Guys - lots of great info - appreciate !
Just a thought - is SMC M 50 having any different coatings or efficiency of them if it comes to flare and loss of contrast in certain situations ? I learnt from other lenses I have or briefly had that results of coating vary between lenses M and A - but never actually got around to test it reliably.
At least from my F50 experiences I know that it does pretty well in strong backlit situations :
K-01, F 50 1.7 @ 2.0 - the light outside was extremely strong so it was impossible to recover anything from that one huge white - even then I had to underexpose like 2 stops to get even this little detail in highlights on that window o.O
Looking for similar shots with manual glass - just to see how well it handles this sort of stuff.
Thanks
