Originally posted by aoeu The A version. Flash automation puts it over the top.
This is a valid point but if I wanted ever use flash with 50mm it would be F50mm 1.7 which I got. For this lens I am thinking of I plan only existing light - or external flash(es) in manual mode and in conjunction with flashmeter.
Originally posted by Just1MoreDave Most of my actual shots are with either the A50/1.4 or the F50/1.7, and I think the pair cover a lot of potential situations. I also have a Super-Multi-Coated Takumar 50/1.4 with the metal focus ring, because t's cool and has an issue that might make it harder to sell. I don't use it a lot because the other 50s are so useful. I like having the option to pop up the flash with either the F or A lenses.
If you were not to using flash at all - would you rather prefer the Super Takumar version over the A version due to any factor ? I agree F50mm 1.7 is just awesome lens.
I have a couple of 55/1.4s but I really like either the K55/1.8 or a Takumar 55/1.8, so these never get used.
Jeez you have 'a couple' of 55 1.4 ?? So what do they do - grow nearby ? :O
But seriously did you ever done any comparison between all your 50-55 1. 4 ? Sounds like you have quite a few of them so would be great if you could put some samples in this thread !
Thanks!
