10-08-2013, 06:09 AM   #1
iht's Avatar
Hood recommendation for M 20/4?
Any hood recommendation for the M 20/4 that will not vignette on a full frame? It has a 49mm filter thread. I can't find an original hood.
I'd be happy with anything not too expensive, e.g. a rubber hood.
Thanks in advance
10-08-2013, 06:38 AM   #2
I do not think such a hood excists. I have one, and even a UV-filter is tricky, you need a thin one, otherwise there will be vignetting
10-08-2013, 06:40 AM   #3
iht
iht's Avatar
QuoteOriginally posted by Macario Quote
It definitely exists - just not enough to go around.
10-08-2013, 08:56 AM   #4
This should work?
UK 49mm 49 mm Wide Angle Metal Lens Hood for Canon Nikon Panasonic Olympus Sony | eBay
10-08-2013, 09:21 AM   #5
pixie's Avatar
how about this one:http://www.ebay.com/itm/Vivitar-Wideangle-Collapsible-Lens-Hood-49mm-Genuine...item2ec7e9d25b
10-08-2013, 07:55 PM   #6
iht
iht's Avatar
Thanks guys. I had a look at those hoods - wouldn't they vignette at 20mm? I would thought that's why the original square hood is so narrow?
10-09-2013, 05:21 AM   #7
QuoteOriginally posted by iht Quote
Use a step-up ring to 52mm or 58mm,
then a hood to fit that diameter.
10-10-2013, 05:33 AM   #8
iht
iht's Avatar
Ah, I see. That could work. Thanks for the suggestion
10-10-2013, 05:49 AM   #9
It's what I did for the M20/4 on an LX.
I already had the big dinner plate hood from an old Takumar 20/4.5,
58mm filter thread, so just converted to that.
In baseball terminology,
it's called "stepping up to the plate".
hood, k-mount, pentax lens, recommendation, slr lens
hood for fa 20 seadog Pentax SLR Lens Discussion 4 01-09-2015 07:15 PM
Lens Hood for Pentax M 50 1.4 montman Pentax SLR Lens Discussion 12 10-07-2012 10:28 AM
A 15mm 3.5, FA 20-35 and M 50 1.4 for $600? what you think? CRPhoto Pentax SLR Lens Discussion 14 08-13-2012 10:26 AM
Hood recommendation needed for A 50mm F1.2 Deimo Pentax SLR Lens Discussion 13 01-20-2010 12:46 AM
All times are GMT -7. The time now is 09:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
