10-08-2013, 10:52 AM   #1
Pentax SMC M 28mm F2: Are there different versions of this lens?
I recently purchased from KEH a Pentax SMC M 28mm F2. I'm hoping this is the lens that was made by Zeiss with the floating element. However, I've heard rumors now that the M series lens is different than an earlier lens, which is the better one that I am looking for.
Does anyone know details about this lens and the different versions, and the quality of these versions?
Thanks!
10-08-2013, 11:25 AM   #2
baro-nite's Avatar
The M version has a different optical formula, and no floating elements.
An excellent resource for such info is Bojidar Dimitrov's Pentax K-Mount Page.
10-08-2013, 12:15 PM   #3
Thanks. I noticed this forum has the M series lens rated very highly at 9.40. Is it your understanding that the M series is still a very, very sharp lens...or perhaps are those reviews actually for the earlier model?
10-08-2013, 12:25 PM   #4
Nick Siebers's Avatar
The two lenses are quite different, so I doubt anyone on the forums would mistake them in doing a review. The M 28/2 is supposed to be quite good, and is smaller and lighter than the earlier "K" 28/2. You may find it does quite well for you.
10-08-2013, 01:02 PM   #5
The two lenses are indeed quite different, especially in size.
I got both lenses and can assure you, both are extremely good, I never came around doing a detailed comparison, but from normal use I'd say the M is not inferior to the K in sharpness and general IQ. I think the lenses have quite a different character, the K's colours seems to be a bit cooler, and it has a nicer "3D" look and a fascinating bokeh, but that's all rather subjective.
I thought about selling the M after I found the K but couldn't really part with it. It produces great images and the small size definitely is a plus.
In short: Use the M28/2 to take a few pictures instead of worrying about not having the K, it is an excellent lens!
10-08-2013, 01:31 PM   #6
baro-nite's Avatar
From Yoshihiko Takinami's resolution tests the M28/2 has exceptional center sharpness from wide open and is as sharp or sharper than the K version at most apertures.
10-08-2013, 02:05 PM   #7
gofour3's Avatar
There is also an “A” version which is the same as the M28/2.
The biggest difference you are going to find with the K28/2 over the others is the close focusing (better minimum distance) and the 3D effect. (More lens elements/groups)
Sharpness wise you will not find much difference between the three and they will also be very close if you shoot at infinity.
Phil.
10-09-2013, 10:30 AM   #8
Thanks for the great insights, everyone. Much appreciated.
28mm, f2, k-mount, lens, pentax, pentax lens, pentax smc, slr lens, smc, versions
Price different on two versions of Pentax D-Li90 Docrwm Pentax Camera and Field Accessories 16 12-16-2015 09:21 AM
Are there different levels of weatherproof Pentax lenses? kshapero Pentax SLR Lens Discussion 3 05-05-2013 10:16 AM
Wanted - Acquired: SMC Pentax 28mm F3.5, SMC Pentax-DA 35mm F2.4 AL, SMC Pentax-F 28mm F2.8 TMoneytron Sold Items 8 07-15-2012 02:54 PM
Two different versions of SMC Pentax-M 50mm f/2 aoleg Pentax SLR Lens Discussion 2 02-13-2012 09:48 PM
Are there two slightly different versions of the FA*85/1.4? dgaies Pentax SLR Lens Discussion 56 11-07-2011 01:27 PM
All times are GMT -7. The time now is 09:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
