10-09-2013, 10:02 PM   #1
My 50-135 is SDM dead....
didn't use for a few month, last month when I took it out, it needs a few minutes to wake up ...
and then today, it totally doesn't work...
I am really unhappy for a $1000 purchase like this. Had it brand new for only 1.5 years and I barely used it
really unhappy. I was thinking of getting a K-3, but now all of sudden I am not sure whether I should stick with RP
Does anyone know whether sending back for service solve the problem? Or the issue comes back soon even after serviced?
10-09-2013, 10:41 PM   #2
gtl
QuoteOriginally posted by ruoyun.huang Quote
Try this
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/208353-how-dea...m-f-2-8-a.html
10-09-2013, 10:54 PM   #3
so bad that I only have a k-5 ... :-(
10-09-2013, 11:59 PM   #4
Servicing will usually fix the problem for long enough, but there's no guarantee that the SDM motor won't break again. I've heard stories of 3 or even 4 SDM replacements on the same lens, though those were certainly extreme cases.
10-10-2013, 04:00 AM   #5
DVaughan007's Avatar
Hey,
I Got 50-135mm SDM motor replaced after 2 years by CRK Australia (Pentax Distributer). Think they charged 211.00 AUD which I thought was a good price.Ever since the lens has worked flawlessly, perhaps even better than it did initially. I get awesome results from this lens so I didn't think twice about replacing the motor. Likewise mine would require a warm up before the focus would function up until it failed completely. I much prefer the silent motor autofocus when compared to screw drive. . Goodluck!
Cheers,
Dan. V
10-10-2013, 07:32 AM   #6
Andi Lo's Avatar
Buy a used K10. They're so cheap these days.... I'd say you can get one well used body only for around 125
10-10-2013, 08:47 AM   #7
Banned
Put a call out there on your local pentax forums and see if someone has an old body they can help you with a FW reassignment.
10-10-2013, 02:33 PM   #8
I had my 50-135 (owned since 2008) serviced by CRIS a couple of years ago, and had the SDM replaced. I use mine very infrequently, and when I went to use it a few weeks ago, it was dead again. I tried to revive it with my K-5 without success, and figured it was totally dead again. I contacted Ricoh, and basically got flipped the bird by them and got told tough luck. I then tried an old K200D body to revive it, and eventually that woke mine up. Not to say that it wouldn't have eventually woken up with my K-5, but the K200D got the job done.
It's amazing that any lens, let alone a lens of this quality, can just go to sleep and have to get woken up somehow. I have printed out all of the materials on deactivating the SDM, but I have no clue how to actually do it with the K200D. So for now, I'll try to keep on top of mine a bit better from now on to keep the SDM working. Good luck with yours OP.
10-10-2013, 02:46 PM   #9
aleonx3's Avatar
Just curios, how to you store your lens when you are not using it? Do you let it stand (up-side-down with pouch) or do you just lay it down horizontally? I have a hunch that if you lay it flat, it may stall, but if you let it stand up (on a shelf) it will wake up much easier. Again, nothing scientific about that... I don't use those two DA* lenses unless I am on assignment to do events because I like to use small primes for ease of carry. When I do need to use those two lenses, I don't get any issues. That is just in my case, and of course ymmv.
10-11-2013, 01:22 AM   #10
Class A's Avatar
Rumour has it that replacement motors from a certain year onwards are different and expected to have better reliability.
I feel that the 50-135/2.8 is such a good lens that it is worth having it repaired or converted to screw-drive. As has been suggested already, you should be able to get access to a body that can change the lens data.
If I were you, I'd definitely not let the experience with (possibly only the old) SDM let me detract from the K-3 or Pentax in general. I agree that there are too many SDM failure stories out there for comfort, but for some the 50-135/2.8 seems to be working just fine and there are a lot of alternative lenses that you could combine with a great body like the K-3.
10-11-2013, 01:58 AM   #11
Banned
Even as a rumor, it's a stretch, as it's been documented on various forums for four years now, the same words about updated parts.
And as an aside, the Tokina-branded variants for other mounts don't seem so problematic. This is the shame because the 50-135 is quite a nice lens optically, but it's available for other mounts, so if you really love it, that lens isn't going to help keep you on Pentax.
10-11-2013, 02:38 AM   #12
Class A's Avatar
QuoteOriginally posted by snake Quote
I'm not talking about a rumour that old. I'm not talking about a single forum member making a claim either.
The recent "SDM replacement" rumour I referred is far less than four years old and several people have referenced Pentax / service people refer to a better replacement.
I personally still wouldn't touch any of the SDM lenses that were problematic in the past (partly because they are APS-C lenses) but if I owned the 50-135/2.8, I'd make it usable again, one way or the other.
10-11-2013, 03:40 AM   #13
Banned
The problem is not a single person has been able to physically confirm the existence of the supposed new parts in the current rumor.
We have people here that have pulled apart their lenses to expose the circuit boards and mechanical focusing parts to photograph them, but in the interest of confirming anything new, no one does anything. No one tries to confirm, while Pentax is on the line with them and their repairs, the new vs. old part numbers (which could indicate a supercession), no one asks for the old parts back (which is your right, particularly in the US, as it's your proof of repair and something I always do to help make sure a repair that was billed for has no question to it). We have many different ways to go and it seems no less shady than it did in 2009. We even have supposed direct contacts and no one is talking.
10-11-2013, 06:09 AM   #14
Class A's Avatar
You are right. It is a shame that this didn't happen yet.
Perhaps it is not possible to demonstrate the existence of new parts, because there aren't any. Could well be the case.
Well, it is a delicate issue for Pentax.
I don't see them ever admitting that there has been a systematic problem with some SDM lenses. If they did that officially, they could get into all sorts of trouble.
For the record, I cannot exclude the possibility of their version of the story -- that SDM failures frequencies are not out of the ordinary and well within what you'd expect -- is true. It surely does not look like the SDM of a 16-50/2.8 or 50-135/2.8 is anywhere near as reliable as the HSM implementation of many Sigma lenses. The latter use large ring motors which are more robust than the micro-motors in the SDM lenses, so I wouldn't be surprised if the real numbers supported the overall impression that certain SDM lenses do have a reliability problem, but at the end of the day, I don't have the failure numbers and only the latter reflect the whole truth.
10-11-2013, 02:25 PM   #15
QuoteOriginally posted by aleonx3 Quote
Depends. Often the case, it is laid down.
k-mount, month, pentax lens, slr lens
Symptoms of SDM failure on 50 - 135 lens BethC Pentax SLR Lens Discussion 33 05-15-2013 10:56 AM
SDM 50-135, not dead, but not working Olek Troubleshooting and Beginner Help 13 12-07-2012 07:42 AM
I guess my DA*50-135mm SDM is dead.. mikerigel Pentax SLR Lens Discussion 41 03-29-2010 08:04 AM
Sent my 50-135 back today...SDM failure. brecklundin Pentax SLR Lens Discussion 7 08-21-2009 11:47 PM
Lens offer from Amazon: DA* 50-135 SDM & DA* 16-50 SDM f8 Pentax SLR Lens Discussion 4 03-25-2008 04:45 AM
All times are GMT -7. The time now is 10:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
