Originally posted by RobG I guess if one really wanted a longer AF lens, it would necessarily mean going to Canon or Nikon...
Since you are probably going to post process, crop and most likely use manual focus to make a successful image, anyway, you might consider a Q7 with PK adapter.
My Q, plus DFA 100/2,8, has the crop factor of a 550mm lens and offers the deeper DOF of a 100mm lens. The kit is very cost effective and light weight (1.15 lbs, incl tripod bracket, battery, strap, SD card, lens hood, etc.). Plus, I don't need a Sherpa, or an SUV, to help carry my gear as I can stuff it all into a jacket pocket and be out the door. While the adapted lens is in-body stabilized and setup somewhat fussy, the biggest challenge is holding a kit this light in weight, steady. In fact, I look for ways to ADD weight. Anyway, if my adapted lens has an FL much greater than 100mm, I find a brace (bean bag, mono-pod, or tripod) helps settle everything down.
...my 2 cents...
Cheers... M
I'll also add that my preferred kit for butterflies/birding/nature is the DA*300/4 paired to a K5IIs. Works great... no problems.
