10-17-2013, 08:29 PM   #1
Replacement bayonet?
I've a lens that I've been using on my Ist*DS for awhile. Recently, it seems that the bayonet has been damaged and it no longer mounts correctly. Seems like it would be simple to replace, but I dont know where to begin looking for a replacement part.
10-18-2013, 02:38 AM   #2
gordon_l34's Avatar
Hi,
Where are you?
Regards.
10-18-2013, 04:47 AM   #3
rbefly's Avatar
New Bayonet?
Hello Kujako, welcome to the forum!
Depending on what series the lens is (fully manual, auto aperture-'A' mount, or fully auto-F, FA, DA) I'd look for a cheap 'non-working' or lens with damaged optics but otherwise OK. Once a lens has (say) bad scratches or barrel/housing issues, they sell pretty cheap. If all you need is the bayonet and it has the right contact configuration, it should work.
Or, take it to a camera repair shop and get an estimate for replacement bayonet. They might even have a spare bayonet to sell.
I've seen scratched-optic lenses sell for $10-$20 on eBay; as long as it's the right bayonet, that should do it.
JMO,
Ron
10-18-2013, 08:47 AM   #4
After some hunting around, I found the following...
Genuine Pentax Replacement Parts from USCamera.com
While it is not the same lens model, it "looks" like the correct part.
10-18-2013, 02:38 PM   #5
jeffw's Avatar
That ring is plastic. You might waant to upgrade to metal if you are going through the trouble.
10-18-2013, 04:37 PM   #6
Well the one it is replacing is plastic, which is why it broke. However I have not found a source for a metal one.
10-20-2013, 11:30 AM   #7
I ordered the above plastic bayonet. We'll see how it goes. I'm a bit nervous about transferring the metal bits from the current damaged bayonet onto the new one, but it's not like I can break it anymore then it is.
k-mount, pentax lens, replacement, slr lens
Takumar Bayonet 28mm strangeboy Pentax SLR Lens Discussion 19 05-12-2016 01:47 PM
Worn Bayonet Lens Hoods WPRESTO Pentax SLR Lens Discussion 9 04-07-2012 06:59 AM
For Sale - Sold: Takumar (Bayonet) 135 f2.5 blackcloudbrew Sold Items 4 01-09-2012 10:30 AM
When is a Pentax bayonet not a Pentax bayonet albrechtnamatdurer Pentax SLR Lens Discussion 6 06-28-2009 09:35 PM
All times are GMT -7. The time now is 06:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
