04-03-2008, 01:58 AM   #16
I really really want to see some pictures taken with this set-up. Those tilt&shift lenses look awesome, but come at quite a price...
Too bad those tilt or shift-adapters only works with pentacon-lenses...
but show us some pics!
04-03-2008, 06:57 AM   #17
Abbazz's Avatar
It reminds me of the Hama tilt&shift bellows:
Manual Focus Lenses :: View topic - Which macro bellows tilt?
Cheers!
Abbazz
04-03-2008, 07:31 AM   #18
aegisphan's Avatar
QuoteOriginally posted by raccou Quote
That's the whole point of tilt/shift. You need a lens that have a much bigger image circle compared to the the 35mm format lens, or else you will have a black out in a portion of the image when you tilt or shift. Pentacon lenses are pretty low in price, adding with the adapters, you have more flexibility with focal lengths compared to getting just one T/S lens. The cheapest T/S at the moment is Arax 35. That's around $500-$600. A tilt or a shift adapter, each costs around $120, adding a lens, like the Vega 90mm for $60 and my recent acquired Flektogon 50/4 for $70. You already have two usable focal lengths instead of being stuck with just one focal. Admittedly, 35 would be much wider than any of the lens i mention. So that's the plus.
04-04-2008, 01:57 AM   #19
QuoteOriginally posted by aegisphan Quote
I had no idea that those lenses were that cheap. And had no idea that the lens had to be bigger. So, those are lenses for medium-format then?
thanks!
04-06-2008, 02:47 PM   #20
Examples, update.
Thanks for all the comments. I had a busy week but got out today to play around with the setup. I used a Rikenon 135mm/3.5 bellows lens. This one focuses to infinity on the bellows. I also got a 60mm enlarger lens but it did not arrive yet. I started to read about t/s, thanks for the zoerk link! There are tons of resources on the web.
With tilt:
no tilt:
with shift:
no shift (not to much of an effect):
with double tilt (X+Y):
no tilt (at least not much):
04-07-2008, 02:34 AM   #21
Another one to look at is Hartblei:
HARTBLEI 35mm Super-Rotator Tilt Shift Lens | HARTBLEI
06-19-2009, 04:30 AM   #22
lenses
try using enlarger lenses or pentax 6x7 90 mm/2.8
06-20-2009, 08:49 AM   #23
kristoffon's Avatar
I always wanted a TS with a wide angle to keep things sharp, instead of blurring them, and was kind of put off since any wide angle MF lens costs a lot.
I never thought of using it for macro though. Certainly a worthy application. I guess I'll be building one to attempt better macro shots - keeping more subject in focus.
camera, k-mount, lens, pentax lens, slr lens
Tilt - shift chromo Pentax SLR Lens Discussion 13 03-05-2010 09:13 PM
the magic of tilt shift redpigeons Photographic Industry and Professionals 13 05-16-2009 10:50 PM
Tilt Shift benjikan Pentax SLR Lens Discussion 34 08-11-2007 02:16 AM
Tilt/Shift and Shift lens Thingo Pentax SLR Lens Discussion 1 11-16-2006 05:03 AM
All times are GMT -7. The time now is 06:15 AM. | See also: NikonForums.com, part of our network of photo forums!
