10-22-2013, 03:59 PM   #1
Fast, cheap WIDE ANGLE (not fisheye) lens?
I have looked into the available lenses already (I still have many lenses to check) but from what I can see you can't get TOO fast... At least not cheap. Wide angle for APS-C, not full-frame... So f/2.8 is fine, anything below is a plus. What is cheap? $200 or $300 or so, I guess. (Naturally less is better if possible.) Go above or below (but not too much) in your suggestions, and I will figure out what to do. I would like to avoid CA and fringing of corse. As much contrast and colors as possible. Muted colors are not nice, but can be corrected. There has to be some contrast originally, the more you correct in post the worse it looks, at least in my opinion. You can't easily add sharpness in post, so sharpness is important. Thank you for anyone who takes the time to help.
10-22-2013, 04:12 PM   #2
panoguy's Avatar
Zenitar 16mm (for full frame). Less than $200, f/2.8, very wide, sharp and contrasty. Yes, it's technically a fisheye lens, so expect some distortion, but on an APS-C sensor it isn't that much. Beyond that, you'd have to list the lenses you've already looked into, since almost all lenses specifically for APS-C are recent, and therefore not going to be that cheap or much faster than f/4.
BTW, you will never avoid CA and fringing with cheap lenses that are "wide on APS-C," so don't even try...
10-22-2013, 04:20 PM   #3
vagrant10's Avatar
or samyang/rikenon/vivitar 14mm f2.8 - manual focus though. I don't own it myself, but heard it's pretty good
10-22-2013, 04:26 PM   #4
QuoteOriginally posted by panoguy Quote
Zenitar 16mm (for full frame). Less than $200, very wide, sharp and contrasty. Yes, it's technically a fisheye lens, so expect some distortion, but on an APS-C sensor it isn't that much...
BTW, you will never avoid CA and fringing with cheap lenses, so don't even try...
Thank you, I will look it up. Russian lenses seem a little hard to find... Unless I buy it from Russia. Why not, but I wonder about the delivery time. And I hate the idea of surprise double/triple taxing by the customs. No sense in buying a cheap lens if the customs charges equal to an expensive lens. thank you for your hopeless (but I believe true) comment. I would buy a more expensive lens but I'm trying to keep my spendings on lenses and accessories for this month (and the next...) under $2000. And even with another cheap lens that will be a stretch. I could wait and buy a better wide-angle later but then i wouldn't get to use it NOW. Compromises...
QuoteOriginally posted by vagrant10 Quote
I will look it up. Manual focus and manual aperture are fine. If I wanted my lens to make coffee and answer my emails for me, I would have mentioned it in the original post.
10-22-2013, 04:28 PM   #5
panoguy: I looked it up: i can get the Zenitar without importing, so that's one option.
10-22-2013, 04:50 PM   #6
jimr-pdx's Avatar
+1 on the samyang 14. I don't mind fisheye so I picked up their 8mm for $200 and it should do the job!
10-22-2013, 04:54 PM   #7
QuoteOriginally posted by jimr-pdx Quote
but i would really rather get a lens that is not fisheye! 36mm is wide-angle on FF and that's 22.5mm on APS-C, so I think 18-22 is good too. 14mm is a little too wide for my liking, and gets the fisheye aberration. I'm looking at some really interesting (rare) lenses right now, but it's impossible to find a seller. I will keep looking.
10-22-2013, 04:56 PM   #8
edit: but the distortion in the samyang 14mm is acceptable, actually I'm beginning to love that lens. Top of my list right now!
10-22-2013, 05:04 PM   #9
WillWeaverRVA's Avatar
Get a Samyang 14mm. I might pick one up myself, I've heard nothing but good things.
10-22-2013, 05:15 PM   #10
QuoteOriginally posted by WillWeaverRVA Quote
I will, if I find nothing else. It's just that I wanted to spend around $200. The cheapest I can find it here is for $470.
10-22-2013, 05:23 PM   #11
If you shop around on the used market you can often find the Sigma 14mm f/2.8 Aspherical for the Pentax mount (autofocus lens) for between $280 and $350. I love the way that wide angle Sigma renders ... and it's crazy cheap. I think the reason it sells for so little is that it can't take filters on the front without vignetting ... unless you use a modified Pro Cokin setup. Here are a couple of my samples from that lens:
F/10
F/3.5 (taken from a moving train):
F/2.8
F/2.8:
This is the lens I'm talking about (new: ~$600, used: somewhere between $280 and $350):
http://www.amazon.com/Sigma-Aspherical-Pentax-Samsung-Cameras/dp/B0000501T1/...ma+14mm+pentax
10-22-2013, 05:24 PM   #12
Try eGlobal
They have it for $293 for their Aussie store.
10-22-2013, 05:39 PM   #13
QuoteOriginally posted by sledger Quote
Try eGlobal
I don't live in Australia and that in no way takes care of the import taxes. I will not pay import taxes, it's a waste of money. Import taxes usually equal to the price of another lens.
QuoteOriginally posted by JJJPhoto:
here
looks pretty good. The filter vignetting is bad. I would have really only wanted to use one filter (CPL) but vignetting makes it a bad option. I don't like imaginary compositions where my actual composition includes areas I need to crop away. Okay, post can also correct vignetting but what if I want to use the lens for video? Vignetting with barrel distortion can be nice for an artistic effect but I don't want the vignetting for every video if I use it for video. I haven't checked my video editing software for devignetting filter but the less hassle the better. I would probably use the CPL rarely but a limitation is a limitation. but i will keep the lens in mind. Right now I can't find it on ebay here though. "0 results." the closest in the results below is Sigma EX Fisheye 15mm F2.8 Pentax, $490 Availability...
10-22-2013, 05:47 PM   #14
paulh's Avatar
The DA16-45/4 isn't fast at f/4, but has excellent IQ with very nice rendering & sharpness. I see them here on the PF Marketplace going for $200-$250 all the time. It's a discontinued model, but nice used copies turn up frequently.
10-22-2013, 05:58 PM   #15
QuoteOriginally posted by tripodquest Quote
Hmmm ... I suspect there's some confusion online. There was an older Sigma 14mm f/3.5 "fisheye" but the only Sigma 14mm f/2.8 lens that I'm aware of is the "Aspherical" ... which is not a fisheye. The images I posted in this thread (all taken with the Sigma 14mm f/2.8 Aspherical) are all essentially straight from the camera. I might have tweaked a RAW slider to two but I didn't apply any lens distortion correction ... which I would have needed to do if it was a fisheye.
KEH has this lens listed for $339, so if you're interested you might want to call them and clarify which lens they're selling.
http://www.keh.com/camera/Pentax-Autofocus-Non-Mfg-Fixed-Focal-Length-Lenses...99074534N?r=FE
The one on Amazon that I linked to is the one I have (not a fisheye). I purchased mine used on Ebay for $350 with free shipping.
Here is an image of the older Sigma 14mm f/3.5 which is a fisheye with greater distortion (although the distortion on the old Sigma 14mm f/3.5 isn't as bad as the Pentax DA 10-17mm Fisheye):
Sigma 14mm f/3.5 Fisheye - cameraporn.net | Flickr - Photo Sharing!
Oh, and regarding the polarizer issue, many people have commented that the Sigma ultra wide angle lenses seem to have an extra coating that is "almost" like a built-in polarizer. I didn't alter the color of the sky in any of these shots:
angle, colors, contrast, k-mount, lenses, pentax lens, post, sharpness, slr lens
Fast Wide Angle Lens Chook Pentax SLR Lens Discussion 46 05-11-2012 11:49 PM
Extreme wide angle portraits (not fisheye) levelred Pentax SLR Lens Discussion 22 04-09-2010 11:30 PM
Cheap, fast wide angle PK Petri 2/28mm ovim Pentax SLR Lens Discussion 2 08-22-2009 10:21 PM
fast wide angle lens Urmas R. Pentax SLR Lens Discussion 15 04-09-2009 12:41 AM
Fast, wide-angle lens Brucie Pentax SLR Lens Discussion 8 01-08-2008 11:46 AM
All times are GMT -7. The time now is 09:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
