Originally posted by Carlos33 Hello
Does somebody know, is there is difference in IQ between the DFA 100mm Macro f2.8 (older, 2009) and the newer WR version?
It would be good a comparision or all the info.
Thanks.
Carlos
Should be about the same or very similar, which is excellent, since technically both use the same optical formula. However, the older original DFA version is not built nearly as well as the WR version, but it does have the mechanical aperture ring which has the "A" setting, so aperture can be set either on the lens or by the camera body. This fact might be important to some users.
The WR construction is rather unique among macro lenses, being then in the upper league from that standpoint. This can be very useful when shooting closeups under drippy conditions, which can make for some beautiful effects.
