10-27-2013, 06:23 PM   #1
Lens Protection Filters
Hi, please bear with me, but there seems to be a lot of stuff on lens filters out there.
Even in this forum.
So here's my simple question. I've just order a K3, my first venture into Digital SLR, since I used the great Canon AE1 years ago (since then, it's be a succession of one digital point and shot usually an all in one 20x zoom "slr" bridge digital camera). But now that I'll be making more serious investments in camera lens, a lot of what I do will be geared (at least initially) towards high school sports. There's always something flying around, so I really feel uncomfortable with "naked" lens (a hood is only a partial solution I think).
So from what I have read, the need for UV protection has gone the way side of film.
So what kinds of recommendations should I consider. I'm thinking I just want a good clear lens filter for protection. I gather if it has got a good muti-coating that flare shouldn't be a problem. I'm usually close to cheer leaders and band "drum corps" so there's a lot of activity. And moisture can be a problem (sometime misty/slight rainy/high humidity at the beginning of fall, etc). But on the track, dust gets kicked up as well. Lighting is tricky, so I am hoping for something that can shed that gritty film that tends to build up.
Nothing really dramatic, but cleaning a lens that's dirty can sometimes mean over time almost cleaning with some grit causing some hazing over time. I'd rather sacrifice the filter then the end of the lens.
Any one have some good suggestions as to what to look for? Low light is a consideration, so I'd rather have a minimal an impact on light transmission as possible (although I'm will to sacrifice some to get protection).
Also, what considerations would there be for polorizers - what does and doesn't work with the newer digital cameras?
Am I just better off to call a camera store and talk to someone for recommendations (although I've read enough out here to know forum members aren't shy! ).
Thanks.
10-27-2013, 07:03 PM - 1 Like   #2
SpecialK's Avatar
There are not going to be any new answers.
10-27-2013, 07:08 PM   #3
If you're worried, get a good quality UV filter. For sports I don't think I'd use a polariser as you'll lose a stop of light, and for fast action that will hinder you (plus polarizers are a lot more expensive than UV filters). Personally I don't use filters just for protection as I don't want anything in front of the lens that could degrade IQ, but I think I may be in the minority.
10-27-2013, 07:46 PM - 1 Like   #4
I shoot a lot of sports and never use a filter. A lens hood is always used and I have never had any issues. Personally IQ is my primary consideration and I don't think a filter would prevent damage to a lens when pucks or basketballs are involved.
It depends on your preference, personally I consider a protective filter a waste of money.
10-27-2013, 08:04 PM   #5
Yep, I'd skip the protector and use the hood. Put the money you saved toward a better quality CPL. That's one item where you pretty much get what you pay for. Good advice above about being careful when to use the CPL. Be sure you can afford the light loss. Only time you really need a protector is on a beach or in a sandstorm (or have some kind of objects flying at you, in which case, turn around and run!)
10-27-2013, 08:08 PM   #6
foto guy's Avatar
If Pentax had meant the lens to have a protective filter, they would have installed one at the factory.
Seriously, unless you're a magnet for flying things, better not to sacrifice image quality.
A circular polarizer could come in handy sometimes, and you certainly will have the capability to crank the ISO without worry, but I wouldn't bother with anything else.
10-27-2013, 08:26 PM   #7
Id skip filters, and spend the money on extended warranties.........
10-27-2013, 08:43 PM   #8
QuoteOriginally posted by DogLover Quote
ditto
CPL filters sometimes live on my lenses. Quality though costs. Never use UV or "lens protector"
cheers
bb2
10-27-2013, 10:07 PM   #9
jatrax's Avatar
Use a protection filter if it makes you feel safer, but all filters degrade the image to some degree. Sometimes it is noticeable sometimes not. But possibly the worst conditions in which to use a filter is sports arenas. The filters often pick up ghosts from the lights.
I never use filters for protection but always use a hood.
10-27-2013, 11:03 PM   #10
littledrawe's Avatar
Whatever, I've been working on some things in my laboratory and I might have found the cure.
10-28-2013, 01:10 AM   #11
Barry Pearson's Avatar
QuoteOriginally posted by jrpower10 Quote
QuoteOriginally posted by Primes4ever Quote
Yes to all of you. I used to use protective filters, then realised that over decades they had not been useful. So I've stopped using them, because I want maximum image quality.
But I didn't throw them away. I carry one of each size in my car so that if I predict I will have problems (children, blown sand, etc) I can take precautions.
(And I have CPLs that I can use on all lenses, because they do things I can't replace with Photoshop. I don't use them for action, but a friend has used them for motor sports to control reflections).
10-28-2013, 02:16 AM - 1 Like   #12
I have always (20 years) used uv or protection filter in all my lenses. Few years ago i did take of filters from most used lenses for less than year or so. All i did get was many permanent marks in front glasses, some of those marks will reduce IQ. I regret i did try without protection filters.
If i would be pro i would not care too much, i would by new lens to replace bad one...but i am not so i can not afford to spoil my lenses. I am still using lenses i did buy 20 years ago, they are in mint condition.
10-28-2013, 05:05 AM   #13
VisualDarkness's Avatar
QuoteOriginally posted by 123jippo Quote
How did you get marks that actually even show in the image?
10-28-2013, 05:33 AM   #14
tiny small lens hood not protect enough.
Also cleaning is more easy and safe for lens if use use filter as protection. Just clean filter when its dirty, can even take dirty filter off and wash with mild dishwashing soup and water.
10-28-2013, 10:21 AM   #15
Rafael's Avatar
I keep a cheap UV filer on most of my lenses at all times. If I'm somewhere where I think the protection is warranted, I leave it on when I take of the lens cover. When I want to take a shot where I'm in control of the situation I unscrew the filter with the cover attached. Twice I've been knocked into while in busy urban centers and had my camera hit the pavement lens-first and both times the cheap filter took the brunt of the impact, distorting the rim and shattering the glass, but leaving my lens unscathed.
camera, film, filters, k-mount, lens, light, lot, pentax lens, protection, slr lens, time
K30 Lens protection synapsestorm Pentax K-30 & K-50 5 08-07-2012 08:24 AM
K5 and WR Lens seals, also useful for dust protection? Origineelreclamebord Pentax K-5 & K-5 II 9 07-28-2012 07:23 AM
DA 12-24 -can i use Protection and plz filters spartan Pentax SLR Lens Discussion 3 07-05-2011 08:08 AM
Which filters? (for lens protection) DanielT74 Troubleshooting and Beginner Help 20 09-24-2009 08:18 AM
Lens Protection David Pentax SLR Lens Discussion 9 11-23-2007 05:56 PM
All times are GMT -7. The time now is 08:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
