Originally posted by Digitalis To quote your findings "It is the glass itself which turns yellow, I cannot rule out that the cement not turns yellow also, but find it unlikely."
The leaded borosilicate glass types found within these lenses have drastically different chemical and mechanical properties than your simplified "smoked quartz" hypothesis is based upon.
It is not my theory, it is the description I found on the internet that did fit the best with my findings.
Feel free to come with a better one, but the canada balsam theory does not fall in that catagory, having yellowed single element non cemented lenses rules that out as the only source of yellowing.
And if you want much more hits on this subject, search for 'browning', and not yellowing.
Then you will find several companies offering special glass for radioactive environments which do not turn brown.
So it is not only crystals.
