11-04-2013, 04:25 PM   #1
Glueing a Loose M Lens Focusing Ring?
My M series 50 mm f1.4 lens is in good working condition except for the rubber/plastic focusing ring rotating loosely, and independently of the underlying focusing helical; the helical itself is fine. It will focus appropriately if I pinch the ring tightly enough to turn the focusing mechanism.
I am thinking of glueing the focusing ring. My concern is that I do not want to glue the lens into a fixed position. The focusing ring appears to be made of plastic rather than rubber, and I seem unsure of how to take it off or loosen it enough to apply the glue.
Any suggestions or ideas?
Thanks.
Sincerely,
Hany.
11-04-2013, 04:36 PM   #2
Just gently work it off over the front, the lip that holds it on is not that big. I prefer to use some double sided tape instead of glue for this.
11-04-2013, 05:14 PM   #3
Otis Memorial Pentaxian
You have to ask yourself though how it got loose in the first place. I bought M 50/1.7 new in 1982 and it is as tight today as the day I bought it. I think Pliobond might be a good option.
11-04-2013, 05:36 PM   #4
tabl10s's Avatar
I used Surfboard Wax that I found at the local camera shop(why they had some is beyond me and the one of the salesmen didn't know)and it worked like a charm. i even use it on the arms of my glasses to stop them from sliding forward. A thin layer is all that's needed and it's what I used on my pristine A50-1.2. You can apply it to the barrel or inside the grip.
glue, k-mount, lens, pentax lens, slr lens
Issue with 01 lens focusing ring Paolo.Bosetti Pentax Q 16 04-07-2014 12:28 AM
Pentax smc-M 50/1.4 focusing ring MattBotan Troubleshooting and Beginner Help 4 06-09-2013 01:04 AM
how to make focusing ring on manual lens less slippery ? glinda Troubleshooting and Beginner Help 14 11-20-2012 06:33 AM
loose DoF ring on Chinon 50mm f/1.7 peedeecee Pentax SLR Lens Discussion 8 08-24-2012 07:56 AM
SMC Pentax-M f1.4 50mm loose front ring? theperception2008 Pentax SLR Lens Discussion 6 05-04-2011 08:06 PM
All times are GMT -7. The time now is 02:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
