04-03-2008, 08:41 AM   #46
ChipB's Avatar
And to further confuse the subjectiveness of "sharpness", some lens manufacturers offer lenses that are purposely designed to be "soft" - so if a "soft" lens has the main subject in focus, is it "sharp"????
04-03-2008, 08:43 AM   #47
Gooshin's Avatar
QuoteOriginally posted by ChipB Quote
its weird, but you can have a sharp soft focus lens... hahaha
i found out by accident that the Zenitar 16mm exhibits such a tendancy at F2.8
its hard to explain, but everything has a halo around it, but at the same time detail is preserved...
(here is the original: http://fork.zenfolio.com/img/v3/p278338912.jpg)
04-03-2008, 08:46 AM   #48
sharpness is definitively NOT SUBJECTIVE
Every medium has a resolution limit, maximum sharpness/detail = max resolution.
What is subjective is the acceptable amount of sharpness, the tolerance.
Back to topic folks!
04-03-2008, 08:47 AM   #49
Gooshin's Avatar
QuoteOriginally posted by ricardobeat Quote
Stay on topic folks!
tell that to someone with bad eyesight...
04-03-2008, 08:56 AM   #50
aegisphan's Avatar
Soft lens has the halo/glowing effect, that I dislike. The subject is definitely not sharp. But for portrait work, sharp is not unnecessary.
Here is what I think is sharp at f/2.5:
Original:
100% Crop:
I tend to shoot at wide open so to really demonstrate what's sharp, I probably need to stop down more.
04-03-2008, 09:03 AM   #51
jsherman999's Avatar
Very cool photo Gooshin.
04-03-2008, 09:28 AM   #52
and
seconded. And I thought the zenitar was really dreamy at f2.8, thats a lot better than shots I have seen from it at f2.8. works fine for me
04-03-2008, 11:56 AM   #53
ukbluetooth's Avatar
Great photo - reminds me of the 60's when, for some inexplicable reason, the door frame (on the left) might really look like that.
04-03-2008, 12:51 PM   #54
I think that my daughter is sharp in the photo Hotdog Roadtrip and the church is quite sharp too, albeit very shrinked here.
Flickr: Photos from zewrak
All taken with the Sigma. However, I am a newbie, so don't be harsh on the quality . The images are sharp to me though.
04-03-2008, 01:00 PM   #55
Nice atmosphere - like them
04-03-2008, 04:41 PM   #56
Canada_Rockies's Avatar
Pentax built a couple of soft lenses. The way they work is that there is a small aperture in the center of the lens, surrounded by additional smaller aperture holes. As you open the lens aperture up, more of the outside ring of holes comes in to play, producing an out of focus glow around a sharp, in focus, image.
If you want to experiment with this sort of thing without spending your hard earned cash, get an inexpensive clear or UV filter for a lens in the portrait range of focal lengths. Grab a jar of "petroleum jelly". Leaving the center of the filter clean, smear some of the jelly around the outside edge of the filter. This is not quite as elegant as the soft focus lens, but does a very close imitation of it. It's also messier.
judge, k-mount, pentax lens, slr lens
Is this as sharp as it should be? Todd Adamson Pentax SLR Lens Discussion 29 11-03-2010 01:34 AM
Nature Sharp enough? christophleipzig Photo Critique 5 10-16-2010 01:40 AM
Is the 16-50mm sharp enough? lbenac Pentax SLR Lens Discussion 5 03-09-2009 03:04 AM
Sharp enough? bsierens Photo Critique 12 11-07-2008 04:53 AM
16-45 versus 20-35 - better sharp? platinum Pentax SLR Lens Discussion 3 07-01-2008 02:19 AM
All times are GMT -7. The time now is 02:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
