11-09-2013, 08:31 AM   #1
Pentax and full portraits?
hello everybody
i just use pentax few month ago & now seeking to take a full body portraits.
My friends use canon 1100D + 85f1.8 can do this very easy
i just wonder what is the lens i can shoot those picture like this :
My body i use is K5 IIs, current lens : 55-300,16-45,70ltd
every time i try to take picture like this my lens goes to infinity range and bokeh gone...
11-09-2013, 09:14 AM   #2
QuoteOriginally posted by nhatdung Quote
On the K5 series, the focus points are actually quite large.
Can you try to get the body of your subject entirely within the focus point?
Another option might be to set facial recognition,
although I've never tried that myself.
11-09-2013, 09:33 AM   #3
Lowell Goudge's Avatar
Image size = subject size x. Focal length / distance
Image size will typically be either 16 or 24 mm because that is your sensor size.
Plug in the subject height and shooting distance you have to work out the focal length you need. You can do full body portraits with any lens, it is all about the distance you have to work with
11-09-2013, 10:20 AM   #4
mattt's Avatar
The Canon is a crop body - find an m85/2 its closest to what your friend used... The distant background makes the scene OOF.
Also Google Ryan Benazier.
He has been associated with a methodology compositing images for a wider field of view that is bokeh-licious.
11-09-2013, 10:24 AM   #5
And remember to set the aperture to as open as possible.
11-09-2013, 02:41 PM   #6
arv
For distant shots I'd suggest Samyang 85mm f1.4; for more comfortable distance and AF - Sigma 30mm f1.4
A.
11-09-2013, 02:41 PM   #7
reeftool's Avatar
I would think your DA 70 Limited would look similar to that shot if you shoot wide open at f/2.4. Since there really isn't anything behind the 2 people in focus except for a small section of blacktop, the bokeh is pretty even. If your camera is focusing on infinity in a shot like this, then you focus point isn't on one of the people but between them. Make sure your focus is locked.
11-09-2013, 03:06 PM   #8
mattt's Avatar
I was thinking the 70 would do it too - I only threw out the M85/2 because its a touch faster and I own one. Actually, following your comment I looked at the pavement closer, and this appears to be front focussed. I still say, based on my experience with M85/2 that this is a Brenizer shot....
The Brenizer Method Explained With Directions | San Francisco Bay Area Editorial Story-telling Wedding Photography
11-09-2013, 03:47 PM - 1 Like   #9
Are you sure your friend's shot is just 1 shot?
I doubt so, since I can't even have it in one shot with a 135/2.5 on my 5D
So your friend certainly did not do it that 'easily'
Read up on the Brenizer Technique as suggested.
The Canon crop factor is 1.6x.
Pentax is 1.5x.
So for the same focal length lens, Pentax will actually be nearer for the same field of view (FOV), so less DOF.
But then, your lenses are different focal lengths.
The 85/1.8 on a D1100 say at a working distance of 6m to do that shot you posted will have DOF of 0.17m
The DA70 at f2.4 for the same framing, will be at a working distance of 4.6m and DOF about 0.21m
Close enough in DOF shallowness for a 1 frame photo.
11-09-2013, 03:48 PM   #10
If you're looking at 85mm and manual - the Rokinon 85mm f/1.4 is good, and not expensive (also a FF lens).
11-09-2013, 03:59 PM   #11
Just1MoreDave's Avatar
The main problem with using a Pentax lens to copy this exactly is getting that veiling flare.
11-09-2013, 09:20 PM   #12
QuoteOriginally posted by pinholecam Quote
yes, he does shot 1 times only
11-09-2013, 09:22 PM   #13
@all : i didn't search for 85mm lens, he also do it use 50mm and i see the picture very nice. I also try 50-135 before and all those lens is good to take half body portraits only
11-09-2013, 10:48 PM   #14
reeftool's Avatar
You should be able to get a similar result with a fast 50 or 55, wide open. At f/1.8 you would only have a few feet of DOF and even less at f/1.4.
11-10-2013, 12:05 AM   #15
arv
IMO it's a long shot taken at a bit lowish angle; thus sky is incorporated, what fakes normal or even wide perspective shot with shallow dof. Look at this example; It's taken with APS-C camera and Samyang 85mm at f1.4.
A.
body, k-mount, lens, pentax, pentax lens, picture, slr lens
Which would be the best lens for full body portraits? Vantage-Point Pentax SLR Lens Discussion 17 01-03-2012 09:20 PM
Pentax and Full Frame oppositz Pentax DSLR Discussion 58 03-18-2011 09:39 AM
Pentax and Full Frame... Shutter-bug Photographic Technique 60 11-03-2010 10:03 AM
Full Length Portraits 31mm or 35mm candgpics Photographic Technique 9 09-25-2009 06:51 AM
Full length (super)telephoto portraits? CSoars Pentax SLR Lens Discussion 14 12-01-2008 01:28 PM
All times are GMT -7. The time now is 09:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
