04-23-2008, 04:03 AM   #46
QuoteOriginally posted by Miserere Quote
Sure, we have a fast(ish) 77mm prime, but at $700 it's out of my reach (and I'm not alone)
Yes...but you have a 70mm that it's cheaper and still an amazing lens. Ok, it's not so fast...but you can't have it all. It's all about options...and while you have plenty of options below 100mm, you have none between 100 and 200mm...let alone above 300mm...but that's another story
04-27-2008, 06:29 PM   #47
Miserere's Avatar
QuoteOriginally posted by mauricio Quote
I have a Tokina zoom that's f/2.8 at 70mm and performs quite well. The reasons I wish to buy primes are:
  1. Better IQ than a zoom
  2. Faster speed than a zoom
  3. Compactness and lightness
The increased IQ isn't a matter of design expertise per se, a good prime that is optically better than a good zoom is easy to build. It's also easier to make a prime faster. I'm not going to spend money on a prime if I'm not gaining both IQ and speed over a zoom. I would also expect it to be cheaper. I'm ready to bet that the profit margin on the 77 Ltd is much higher than that of the DA* 50-135mm, despite similar price tags. And I would love for somebody to test these two at f/2.8 to see exactly how much IQ we gain from shooting the Ltd...if any.
It's not hard to build an 85mm f/2, so please Pentax, get us a DA 85mm f/2 for no more than $400, will ya?
04-28-2008, 02:56 AM   #48
I agree with your points but I would add "quality of construction" as number 2. That's why I like the limited lenses so much. They have the IQ, they have the compactness and lightness and yes, they could be a bit faster...but personally I rather have a metal lens and a bit slower than a plastic lens a bit faster...but that's just me To make the 70 faster or create an 85mm with the same quality of thr 70mm and faster, it would certainly mean that it would cost the price of the 31mm limited.
04-28-2008, 03:33 AM   #49
Miserere's Avatar
Some people will sacrifice speed for size, but I'm not one of them. Primes under 100mm are compact enough for me, so I would rather have the speed.
Maybe Pentax cannot justify the production costs of having parallel lines of lenses: The elite, pricey, compact Ltds on one hand; and the standard-size, more economic, fast DAs on the other.
04-28-2008, 04:50 AM   #50
That's probably it. One of the things that bothers me with Pentax bet on the DA lenses is a future full frame Pentax body.
04-29-2008, 03:17 AM   #51
takumar 135 f2.5 ....
i've bought a super - multi - coated takumar 135 f2.5 screw mount with the series number : 6616723, how i can know it version? some body told me version 1 is the best. how about this version 2? thank !!!
05-24-2008, 03:12 PM   #52
I just bid 31 dollars on a Takumar 135mm f/2.5 on ebay.
05-24-2008, 04:06 PM   #53
danielchtong's Avatar
QuoteOriginally posted by anomaly Quote
Well . I can manage using film to shoot DA200mm to get the FoV of a 135mm. Nah. That reminds me to use my FA135mm more instead.
We have been dealing with it (shortage of some key FL). 70-200mm being the most acute one as there is a premium of $200-300 to get a used Sigma lens.
Daniel
05-24-2008, 09:59 PM   #54
I read from somewhere that one should avoid the K-mount Takumar (Bayonet) 135mm f2.5. This is because its has no or single coating and hence suffers from flares. This lens has "Takumar (Bayonet)" marking on the lens barrel, instead of the usual marking on the lens rim.
The better choice would be Super Takumar M42 mount 135mm/f3.5.
Good luck!
05-24-2008, 10:26 PM   #55
frank's Avatar
QuoteOriginally posted by fastfood Quote
Actually there are three version of Takumar 135/2.5 lens in M42 mount. The first version is the Super Takumar 135/2.5 which doesn't have Super Multi Coating (but some reported the later product batch might have too), the second version is Super-Multi-Coated Takumar 135/2.5 with a production code of 43802 (it's at the bottom of the lens, marked on the A/M or Auto/Manu switch). The third version is also Super-Multi-Coated Takumar 135/2.5 w/ a production code of 43812. The second version has a 4 elements in 4 groups optical design while the third one has a 6 elements in 6 groups design.
All these three versions are excellent, the third one (6 elements in 6 groups) is reported to be the best among all three.
The later SMC K 135/2.5 (also 6 elements in 6 groups) is reported to have the same optical design as the last S-M-C Takumar 135/2.5.
You can see more Takumar lens types here:
View all Takumar lens types
k-mount, mm, pentax, pentax lens, slr lens
Fixed aperture manual lens help Joe Troubleshooting and Beginner Help 7 09-01-2010 10:38 PM
Looking for a general-purpose, bright, fixed f lens Fallingwater Pentax SLR Lens Discussion 8 03-04-2010 09:40 PM
Freebee lens fixed! ismaelg Pentax SLR Lens Discussion 6 09-26-2009 07:20 AM
A Pentax fixed/calibrated DA* 16-50mm lens? nicedog Pentax SLR Lens Discussion 0 08-17-2008 11:17 PM
1 everyday fixed lens: advice requested arthur pappas Pentax DSLR Discussion 23 01-24-2008 05:12 PM
All times are GMT -7. The time now is 07:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
