11-14-2013, 02:03 PM   #1
tromboads's Avatar
35mm M slow blade return. Lend a spring?
Good Morning, Good Evening :P
My M 35mm f2.8 has been sitting in the draw and now the aperture blades refuse to return to a closed position with any kind of haste.
My initial investigations from this place tell me its likely the spring has just worn and needs to be turfed.
No worries :P
I have a 50mm M that has offered to be a sacrifice.. I'll keep you posted, unless anyone chimes in now and explains this wont work?
I haven't had either apart, but I cant imagine the build to be dissimilar. I suppose the other thing to do is just take a few coils of the faulty spring.. Will get some pics up either way when I have a crack a little later.
11-14-2013, 03:26 PM   #2
johnha's Avatar
For some reason the M35/2.8 seems prone to this problem much more so than other lenses, not sure if this helps though...
11-14-2013, 04:00 PM   #3
My reading on this lens suggests that the aperture blades can become sticky over time, particularly if the lens has been in warm conditions. They might need to be disassemled and cleaned.
11-14-2013, 04:06 PM   #4
ChrisPlatt's Avatar
On this model lubricant from the focusing helical deposits on aperture blades.
They'll need cleaning with solvent if you want lens to operate normally again.
Eric Hendrickson http://www.pentaxs.com fixed mine for me.
Chris
11-14-2013, 05:52 PM   #5
tromboads's Avatar
Can't wait to have her open. interesting that this one is a common fault.
Blades look clear as the sky, still will have a look either way. Will be happy if I don't have to dismember a 50mm M too if I'm honest.
TO BE CONTINUED!
11-15-2013, 09:33 PM   #6
tromboads's Avatar
Well I cant get the screws of the back safely. :S I have destroyed one that will probably need drilling now
siiiiiiiiiiigh
11-15-2013, 10:25 PM   #7
Not a Number's Avatar
You are using JIS drivers correct?
https://www.pentaxforums.com/forums/114-maintenance-repair-articles/119344-cr...s-caution.html
11-16-2013, 07:03 AM   #8
reeftool's Avatar
It likely just needs a cleaning. As Chris suggested, send it to Eric. I had the same issue with my DA 40 Ltd and he fixed it for around $50 plus shipping.
11-16-2013, 07:27 AM   #9
boriscleto's Avatar
QuoteOriginally posted by reeftool Quote
The OP is from Australia...
11-18-2013, 01:42 PM   #10
tromboads's Avatar
Son of a!
No I was not.
Thank you very much for that!
11-18-2013, 02:24 PM   #11
boriscleto's Avatar
QuoteOriginally posted by tromboads Quote
Son of a!
No I was not.
If you have stripped out the head, try putting a rubber band on the screw head and then using a Philips head screw driver.
01-27-2014, 12:04 AM   #12
tromboads's Avatar
Well I have a confession to make... *shy*
Click
Yes that is the screw I drilled out in effort to get the spring back on, and yes that is the aperture lever I did cut in order for it to clear the K-mount.
As others before me have mentioned, it was simply oily all over the place. I took a link out of the spring in effort to combat this but to no avail. I say this because the screws getting into the rest of the lens have been used before. It seems I was not the first to have opened here and have a fiddle! One of the internal screws had it's head stripped as well, the others were in good condition. I can only imagine someone similar to me got as far as that, destroyed one head and put it all back together before she / he did any more damage :P
I wasn't about to drill another out when the option of cutting the aperture lever still gives me a functional lens. So that's what happened. I'm sure a Panda somewhere cried out in pain as I cut it. I felt a movement in the force. It might have been you lot twitching in unison fearing another hipster with a Canon found some Pentax glass and an tutorial.
FEAR NOT!
It shall still be looked after here be me
Also, note the serial;
Click 2
For if I shall depart this place and you stumble upon it, you shall know it's story, and know it was cherished. :P
01-27-2014, 03:48 AM   #13
tromboads's Avatar
Also.
Click
Didn't break it
k-mount, pentax lens, return, slr lens
Recommendation on a M 35mm 2.8? rzarector Pentax SLR Lens Discussion 5 05-17-2013 02:34 PM
M 28mm f/2.8 slow aperture kcobain1992 Pentax SLR Lens Discussion 8 04-22-2013 01:17 PM
Never lend your 645D out Underbridge Pentax Medium Format 19 01-10-2013 12:40 PM
My Poor smc Pentax-M 50mm f1.7 (Aperture Blade Problem...) AaronBHicks Pentax SLR Lens Discussion 7 01-30-2011 11:00 AM
Abstract Return to sender (slow shutter tennis) coachteeter Post Your Photos! 2 04-20-2010 11:14 PM
All times are GMT -7. The time now is 07:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
