Hey,
I have a Pentax K 24mm f.2.8 lens that needs a hood. I can not not find the dedicated hood at the moment but I have found a PH-S52 hood designed for the 28mm 3.5 lens.
1: Will this hood (which from pictures looks very very similar) work on my 24mm without vignetting.
And/or:
2: Would a regular wide angle 52mm threaded hood work just as well??
Thanks so much.
NOTE - I am shooting 35mm film ONLY, so no crop censors
Reason: more info
