11-16-2013, 11:38 AM   #1
What classic 70 200 manual focus should I look for for an LX
What classic 70 200 manual focus should I look for for an LX?
11-16-2013, 12:08 PM   #2
monochrome's Avatar
Vivitar Series 1 70~210/2.8~4 Macro ZOOM version 3. Get the one manufactured by Komine (first two serial number digits are 28). Many copies (but not all copies) of the Komine lens have "A" contacts which won't be useful with an LX, but even today it is a Cult Classic manual focus zoom. Take care to inquire about zoom creep. Many of these suffer from worn felts but tight zoom rings can be found. $125 - $175 EX with hard case.
Old Mark Roberts post.
11-16-2013, 12:11 PM   #3
QuoteOriginally posted by Johnyb3000 Quote
Pentax has a nice and affordable A-series 70-210mm:
SMC Pentax-A 70-210mm F4 Reviews - A Zoom Lenses - Pentax Lens Reviews & Lens Database
11-16-2013, 01:13 PM   #4
I have one and like it a lot. Here is one perfect for the LX because the A pin is missing.
https://www.pentaxforums.com/forums/24-photographic-equipment-sale/235225-sal...-3-komine.html
11-16-2013, 03:53 PM   #5
There are also the Tamron Adaptall-2 lenses to consider:
SP 70-200mm f/3.5, Model 19AH. See Adaptall-2.org: Tamron SP Adaptall-2 70-210mm F/3.5 Model 19AH
SP 80-200mm f/2.8 Model 30A: See Adaptall-2.org: Tamron SP Adaptall-2 80-200mm F/2.8 LD Model 30A
Both are great lenses but also somewhat rare/much sought after. I have the Model 30A and have only good things to say about it. You can find my own review here: Tamron SP80-200mm f/2.8LD Model 30A (Adaptall-2 system)
11-16-2013, 04:25 PM   #6
monochrome's Avatar
The 19AH is actually a better lens than the Viv Series 1 for sharpness and natural color rendering (IMHO - I've had both). For an LX the user wouldn't need the adapter A either - a $75 cost advantage.
Further - the construction of the Tamron prevents zoom creep. It is just harder to find than the Vivitar and more expensive.
The Pentax Adam suggested is also a fine lens and probably the best value of the lot. I had one but returned it because of zoom creep (and never went to that camera store again - the salesman was a total jerk about it).
11-16-2013, 04:39 PM   #7
Back in the day, I really wanted the SMC Pentax -M zoom 80 ~ 200mm f/4.5
My old -M lens catalog here says it was 141.5mm long and only 555 gram.
"..ideal for ... quick action demands of wildlife.....on the spot news photography..... excellent for ... candid portraits."
I couldn't afford it and had to make do with a Tamron 70 ~ 210 which was a good one too.
I learned how to use it for kids shots wide open at 70mm to get isolated leafy green backgrounds in the garden - rather good.
11-16-2013, 05:54 PM   #8
I can personally vouch for the A 70-210 f4 and Tamron SP 80-200 f2.8 as I use both frequently. The latter is about the only zoom whose IQ good enough to really stand up to use with TC, IMO -- considerably better than the more common Tokina 80-200 f2.8 SD MF zoom.
Early on in my Pentax DSLR experience (2K4-2K6) I was actively seeking, but never found a Series 1 Komine that I could justify buying. Their reputation is notable, and has stood up over time. Of course, after I gave up on getting one, they started becoming offered at reasonable prices much more often, but I just don't use the FL range enough to justify adding one to the collection.
The A 70-210 is probably the best bang for the buck. Traditionally, it's been very commonly offered, and priced consistently under other lenses with its spec.
Scott
11-16-2013, 09:19 PM   #9
QuoteOriginally posted by elliott Quote
I just sent a PM to this listing, thanks for the heads up!
11-16-2013, 09:21 PM   #10
All of you are awesome and I thank you each for your ideas. I have the feeling that I am going to end up with more than one lens in this adventure. Thank you!
11-16-2013, 09:46 PM   #11
I have the Tokina, the Vivitar (Ver 3), a Sigma 75-250, Sears 80-200 and the Pentax-A, and while it has been awhile, I used all but the Tokina on my old LX. While the Pentax is only F4 (constant), as some others have said, for my money it is probably the best of the lot balancing both price and performance, especially on digital. I have found that the Vivitar (and I had two for some reason) was a better lens on film than it is on digital, especially wide open, and back in the day I would usually either grab the Vivitar or the Pentax with the choice being based on the filter size of the lens, they were really that close.
When it comes to film to be quite honest I don't remember there being that much difference in the lenses because I shot and developed a lot of Tri-X and never 'pixel peeked" (except to the extent of a 16x20 print), even on Kodachrome (moot point now) the differences were small, although there was probably a slight difference in color rendition between them, but nothing glaring that I recall. I often kept track of exposure information when I shot but for some reason never kept track of the lens that I used and I don't think today I could tell which shot was taken with which lens. The Sears may have been a bit darker in the corners (and it said 'Sears' on it), the Vivitar may be a bit sharper in the mid focal ranges and the Pentax sharper up close. The main difference in the lenses was the way they handled "macro" modes, I think any of them would do just well as the other on the LX, just make sure you use a lens hood and any of them should be fine.
11-16-2013, 10:44 PM   #12
dms
I also suggest the VS1 70-210 mm Version 3. One of the sharpest lenses I own (comparable to the 50mm f/1.7 and 135mm f/2.5 K-SMC) based on usage (not testing). Partly so good because the visual contrast is high--so for me for theatre work it allows better/faster manual focusing. Also the handling (push-pull) works best for me!
11-17-2013, 02:22 AM   #13
I know it's not exactly what you're after, but could I suggest the Pentax M 75-150/4. OK, it hasn't quite the reach, but it's relatively compact and light, it has excellent IQ (and probably better flare resistance than Tamrons and Vivitars), and should be easy to find and cheap to buy.
11-18-2013, 12:38 PM   #14
gofour3's Avatar
+3 for the Pentax A70-210/4.
Phil.
11-18-2013, 12:51 PM   #15
Lloydy's Avatar
In order of personal preference - 1. the Komine Vivitar S1 70-210 / 2.8 - 4, it's a terrific lens. 2. I've just bought an old Tamron Adaptall BBAR Macro 85-210 / 4.5, and it's another superb lens. But not that common. 3. Tokina AT-X SD 80-200, it's fast and very good.
But I'd take the Vivitar every time, it just delivers!
focus, k-mount, lx, pentax lens, slr lens
Should I get an LX? Alan Clogwyn Film SLRs and Compact Film Cameras 29 11-17-2011 03:55 PM
FA* 200/4 Macro with removed aperture lever shield. What should I ask for? Clinton Pentax SLR Lens Discussion 42 09-25-2011 09:15 PM
Buying lenses from Craigslist, what should I look for? mojoe_24 Troubleshooting and Beginner Help 28 01-29-2011 04:34 PM
About to go to a store to inspect a used 77mm 1.8 Limited. What should I look for? uchinakuri Pentax SLR Lens Discussion 3 07-06-2010 10:54 AM
flash for K100D: what should I look for? WMBP Flashes, Lighting, and Studio 8 03-01-2007 03:20 AM
All times are GMT -7. The time now is 03:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
